Home » Eclipse Projects » Rich Client Platform (RCP) » Wizard dialog resize weirdiness
Wizard dialog resize weirdiness [message #498975] Thu, 19 November 2009 07:01 Go to next message
Hi.
I have a weird issue with a wizard that is using WizardSelectionPage as
the first page: when the user selects one of the available wizards,
click next button (the new wizard page is displayed correctly) then
resizes the dialog, the page is switched back to the first
WizardSelectionPage but the wizard still thinks that the page was not
switched (i.e. next button doesn't work because the new wizard isn't
completed).
It seems that the dialog doesn't know what is the topmost composite when
reisizing. I don't think it is an internal issue but I can't find any
reason of this behaviour.
Anyone has an idea or some suggestions on how to debug this issue ?
Marco.
Re: Wizard dialog resize weirdiness [message #498984 is a reply to message #498975] Thu, 19 November 2009 07:40 Go to previous messageGo to next message
Hi Marco,
This can be caused by not setting the control in your wizardpage:
public void createControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
// Draw on composite
// call setControl
setControl(composite);
I hope this solved it,
Wim Jongman
> Hi.
> completed).
> Regards,
> Marco.
Re: Wizard dialog resize weirdiness [message #499024 is a reply to message #498984] Thu, 19 November 2009 10:03 Go to previous messageGo to next message
> // call setControl
All pages sets the control correctly, if I'm not wrong the wizard throws
an exception if the control is not set.
In addition, this issue appears only when I'm using a
WizardSelectionPage and only on Windows platform. The same application
running on Linux works fine.
Marco.
Re: Wizard dialog resize weirdiness [message #499163 is a reply to message #498975] Fri, 20 November 2009 03:29 Go to previous message
> completed).
I found the cause: the WizardSelectionPage was composed of a single
table so I used the table widget as the page control. Believe it or not
this caused the resize issues in Windows, I had to add a composite
container around the table and use that composite as the page control.
So today's lesson is: always use a composite to wrap controls, even if
you believe it is not necessary and is a waste of resources.
Marco.
Previous Topic:Opening a plain file in filesystem in org.eclipse.ui.DefaultTextEdtior
Next Topic:Compute Dependencies for Feature
Current Time: Wed Jul 23 04:52:04 EDT 2025
Powered by FUDForum. Page generated in 0.28089 seconds
