Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Layout not based on content of control
Layout not based on content of control [message #498938] Thu, 19 November 2009 04:49 Go to next message
Hi there,
is there a way to make controls compute their preferred size not based on their content or make a layout ignore the control's preferred size and use the constraints provided in the layout data only?
Background:
I've got a Scrolled Form which contains a multi-line Text in a Section. The Text has a vertical scroll-bar only and the wrap bit set. The Text is inside a GridLayout and has a GridData, with SWT.FILL on the horizontal alignment and a fixed vertical size.
Entering a long text without any whitespace will cause the control to increase it's horizontal size dramatically when the View is re-layouted (happens when opening and closing sections of a the form for example).
Josef
Re: Layout not based on content of control [message #498939 is a reply to message #498938] Thu, 19 November 2009 04:54 Go to previous messageGo to next message
Probably using a FormLayout might help?
Tom
JD schrieb:
> Hi there,
> Background:
> horizontal alignment and a fixed vertical size. Entering a long text
> Cheers,
> Josef
Re: Layout not based on content of control [message #498944 is a reply to message #498939] Thu, 19 November 2009 05:16 Go to previous messageGo to next message
Tom Schindl wrote on Thu, 19 November 2009 04:54
Tom
Thanks.
From a quick look into the JavaDoc, I think not, since there is nothing that would prevent the Text from growing vertically in the rest of the Form, so the Text would still be the dominant control.
On another note, I'd like to prevent exchanging the layout algorithm, since it would affect quite large portions of the code.
In the meantime I found a sort of workaround here in Example 4.
Basically you set the size hints to what they would be for the empty control.
It works in my case, but I'm, still looking for a proper way to do this, as the workaround does not work in cases, where the content is assigned before the layout data.
Re: Layout not based on content of control [message #499014 is a reply to message #498944] Thu, 19 November 2009 09:37 Go to previous messageGo to next message
Setting a widthHint and/or heightHint in the control's GridData is the
proper way to specify a control size that's != its preferred size. The
approach that you listed in your first message sounded right. I don't know
much about ScrolledForm and Section since they come from ui forms, maybe
they're doing something to not consider your set GridDatas? Are you able to
provide a reproducable case that shows your problem (ideal template:
http://www.eclipse.org/swt/faq.php#whatisasnippet )?
Regarding the workaround, you can determine the size of an empty Text at any
time with "Text text = new Text(parent, style); Point size =
text.computeSize(SWT.DEFAULT,SWT.DEFAULT);text.dispose();".
Grant
"JD" <duschl@creamteam.de> wrote in message
news:he35tr$l8d$1@build.eclipse.org...
> > Tom
> Thanks.
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/reference/api/org/eclipse/jface/layout/GridDataFactor y.html
in Example 4.
control.
Re: Layout not based on content of control [message #499189 is a reply to message #499014] Fri, 20 November 2009 05:55 Go to previous messageGo to next message
Hi Grant,
There already is reproducing code here (well sort of):
http://www.eclipse.org/articles/Article-Forms/article.html
(Relevant section highlighted)
I think I can put together a snipped next week though, if you like.
Grant Gayed wrote on Thu, 19 November 2009 09:37
Grant
Re: Layout not based on content of control [message #499260 is a reply to message #499189] Fri, 20 November 2009 10:24 Go to previous message
The snippet below is based on the one from the forms article. It updates
the Link's GridData's width hint, and therefore where it wraps, based on
size changes in its parent.
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.ui.forms.widgets.*;
public class Main0 {
final Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(200, 200, 400, 400);
shell.setLayout(new FillLayout());
FormToolkit toolkit = new FormToolkit(shell.getDisplay());
Form form = toolkit.createForm(shell);
form.setText("Hello, Eclipse Forms");
GridLayout layout = new GridLayout();
form.getBody().setLayout(layout);
final Hyperlink link = toolkit.createHyperlink(form.getBody(), "",
SWT.WRAP);
link.setText("This is an example of a form that is much longer and will
need to wrap. " +
"This is an example of a form that is much longer and will need to
wrap.");
link.setLayoutData(new GridData());
link.getParent().addListener(SWT.Resize, new Listener() { // <----
public void handleEvent(Event event) {
Rectangle rect = link.getParent().getClientArea();
((GridData)link.getLayoutData()).widthHint = rect.width;
link.getParent().layout();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
shell.dispose();
display.dispose();
HTH,
Grant
news:he5sj5$sui$1@build.eclipse.org...
> Hi Grant,
http://209.85.129.132/search?q=cache:cwaR0Mind7sJ:www.eclips e.org/articles/Article-Forms/article.html+inurl:http://www.e clipse.org/articles/Article-Form
s/article.html+%22Although+we+instructed+the+control+to+wrap ,+it+did+not+mat
ter+because+GridLayout+requires+that+a+control+return+its+si ze+in+isolation%
22&cd=1&hl=en&ct=clnk
> > Hi,
know
able to
any
> > Grant
Previous Topic:Drop Target Not Accepting Drops
Next Topic:SWT app running as collection of plugins, not JARs?
Current Time: Sat Jul 26 03:19:46 EDT 2025
Powered by FUDForum. Page generated in 0.09839 seconds
