Bundle classpath configuration in developer mode [message #498864] |
Wed, 18 November 2009 15:40  |
I hope this is the right group to ask this kind of question (pardon me if it isn't).
I'm having trouble with an eclipse product I'm developing plugins for, when I launch it from the PDE. Apparently, the product gets launched in developer mode (with the -dev cmd line option), which is perfectly ok. The PDE also creates a dev.properties file in the workspace under
.metadata\.plugins\org.eclipse.pde.core
which contains the classpath for each bundle as a comma separated list of jar files. As far as I can see with no particular ordering of the jars. (I would have expected it to be the order given by the Bundle-classpath entry in the manifest file of the respective plugin.)
In most caes this wouldn't be an issue, however I got some jars containing the same package/class names, which I can't modify, and it's crucial the classloader searches the jars in this particular order.
If I launch the product as standalone, the ordering specified in the manifest file is preserved (I suppose), in any case it works in standalone mode.
Is there any way to change the order of the jar files on the bundles' classpath / the contents of the dev.properties file? (Editing the dev.properties file manually won't work, as the file is generated on each start)
tnx in advance
[Updated on: Thu, 19 November 2009 03:57] by Moderator
Re: Bundle classpath configuration in developer mode [message #498964 is a reply to message #498864] |
Thu, 19 November 2009 06:03  |
Ok, I found a way to work around the problem, just in case anybody else runs into it.
I copied dev.properties to some other folder so it won't get overwritten, and set the -dev property manually (via the launch configuration menu).
Still, not too happy with that, as I will need to keep my copy of dev.properties in sync with the original one.
No Real Name wrote on Wed, 18 November 2009 15:40 | I hope this is the right group to ask this kind of question (pardon me if it isn't).
tnx in advance
FUDForum. Page generated in 0.32977 seconds
