[EMF Compare] Move of an element [message #498719] |
Wed, 18 November 2009 06:06  |
Originally posted by: mail.andreasscharf.com
I have a question concerning the comparison between UML files. I have
the following example models:
ModelA
|- Foo
|- +someAttribute:Integer
ModelB
|- Foo
|- Bar
The scenario was as follows: I created a new class in ModelB 'Bar' and
moved the attribute 'someAttribute:Integer' from 'Foo' to 'Bar'.
What I was expecting is the ADDITION of 'BAR' and a 'MOVE' of
'someAttribute:Integer' from 'Foo' to 'Bar' but what I get is: ADDITION
of 'BAR' and DELETE of 'someAttribute:Integer'.
I ensured that the XMI IDs are the same and the OPTION_IGNORE_XMI_ID is
turned off to give the match engine the chance to do the match.
Am I doing anything wrong or is this behavior a bug?
Kind regards,
Andreas
Re: [EMF Compare] Move of an element [message #498797 is a reply to message #498736] |
Wed, 18 November 2009 11:34  |
--------------020308050609090304000900
Andreas,
We had nothing planned for this, I then went ahead to try and find at
least *when* we would be able to implement this ... and I ended up
thinking that it's pretty much impossible to /generically/ determine
that a given unmatched element is really a move. See my comment on the
bug, we can continue discussing the issue directly there if it's ok for you.
Laurent Goubet
Obeo
Andreas Scharf wrote:
> Hi Laurent,
> thanks for moving the topic and pointing me to the bug. Any hints to
> (fast) workaround this issue?
> Andreas
> Laurent Goubet schrieb:
>> Hi Andreas,
>> Please use the EMF forum for questions on EMF Compare, I've added it
>> to the To: list of this reply.
>> This is bug 263200
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=263200 we haven't looked
>> into yet.
>> The jist of it is that we only detect top-level changes for additions
>> and deletions : we do not go "inside" the added/deleted element to see
>> if other differences such as move can be detected there.
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> ModelA
>>> |- Foo
>>> ModelB
>>> |- Foo
>>> |- Bar
>>> and moved the attribute 'someAttribute:Integer' from 'Foo' to 'Bar'.
>>> ADDITION of 'BAR' and DELETE of 'someAttribute:Integer'.
>>> is turned off to give the match engine the chance to do the match.
>>> Kind regards,
>>> Andreas
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------020308050609090304000900--
Re: [EMF Compare] Move of an element [message #621597 is a reply to message #498719] |
Wed, 18 November 2009 07:48  |
--------------010206090205010600070903
Hi Andreas,
Please use the EMF forum for questions on EMF Compare, I've added it to
This is bug 263200 https://bugs.eclipse.org/bugs/show_bug.cgi?id=263200
we haven't looked into yet.
Laurent Goubet
Obeo
> ModelA
> |- Foo
> ModelB
> |- Foo
> |- Bar
> Kind regards,
> Andreas
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------010206090205010600070903--
Re: [EMF Compare] Move of an element [message #621598 is a reply to message #498730] |
Wed, 18 November 2009 08:05  |
Hi Laurent,
Andreas
> Hi Andreas,
> Laurent Goubet
> Obeo
>> Hi,
>> ModelA
>> |- Foo
>> ModelB
>> |- Foo
>> |- Bar
>> Kind regards,
>> Andreas
Re: [EMF Compare] Move of an element [message #621599 is a reply to message #498736] |
Andreas,
Laurent Goubet
Obeo
> Hi Laurent,
> Andreas
>> Hi Andreas,
>> This is bug 263200
>> into yet.
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> ModelA
>>> |- Foo
>>> ModelB
>>> |- Foo
>>> |- Bar
>>> Kind regards,
>>> Andreas
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
FUDForum. Page generated in 0.04288 seconds
