[EuGENia] [message #498724] |
Wed, 18 November 2009 06:55  |
Originally posted by: arendt.mathematik.uni-marburg.de
Using EuGENia two questions arose when specifying source and target of a
link:
1. How can I specify elements in an EList?
2. How can I navigate to other related EClasses?
Consider the following example:
class Classifier{}
@gmf.node
class Class extends Classifier{}
class Property extends Classifier{
ref Classifier type;
If I want to specify Associations like in UML, I think of this solution:
@gmf.link(source=X, target=Y)
class Association {
val Property[2] ownedEnds;
where X had to be set to "ownedEnds.get(0).getType()" or something like
this. Who can help to specify X and Y???
Thorsten
Re: [EuGENia] [message #498733 is a reply to message #498725] |
Wed, 18 November 2009 07:54  |
Hi Dimitris,
Thanks a lot, it works!
I specified in the model:
@gmf.link(source="source", target="target")
class Association {
derived ref Classifier source;
derived ref Classifier target;
.... and implemented in AssociationImpl.java:
public Classifier getSource(){
return getOwnedEnd().get(0).getType();
public Classifier getTarget(){
return getOwnedEnd().get(1).getType();
Thorsten
Dimitris Kolovos schrieb:
> Hi Thorsten,
> It seems that setting both the source and target to "ownedEnds" doesn't
> work. I'd recommend trying to create two derived features and setting
> them as the source and target of the link respectively:
> @gmf.link(source="source", target="target", label="name")
> class Association {
> ref Property[2] ownedEnds;
> derived ref Property source;
> derived ref Property target;
> You'll then need to implement the logic in which the features are
> derived from ownedEnds by customizing the generated EMF code - don't
> forget to set @generated NOT in the methods you change. I must admit I
> haven't tried it but it should work. Please let me know if it doesn't
> and I'll have a closer look.
> Cheers,
> Dimitris
> Thorsten Arendt wrote:
>> Hi,
>> link:
>> class Classifier{}
>> @gmf.node
>> class Association {
>> Regards,
>> Thorsten
Re: [EuGENia] [message #582980 is a reply to message #498724] |
Wed, 18 November 2009 07:14  |
Hi Thorsten,
class Association {
Dimitris
> link:
> class Classifier{}
> @gmf.node
> class Association {
> Regards,
> Thorsten
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [EuGENia] [message #582998 is a reply to message #498725] |
Hi Dimitris,
class Association {
Thorsten
> Hi Thorsten,
> class Association {
> Cheers,
> Dimitris
>> Hi,
>> link:
>> class Classifier{}
>> @gmf.node
>> class Association {
>> Regards,
>> Thorsten
FUDForum. Page generated in 0.04014 seconds
