Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Acceleo] Arguments list in Generator-API
[Acceleo] Arguments list in Generator-API [message #498694] |
Wed, 18 November 2009 03:09  |
Hi all,
i successfully started some transformations via the
Accelo.doGenerate-API. It is very convenient and intuitive, so far. But
what can be passed as arguments?! I tried to understand by browsing the
code, but i didn't get a clue, what should be passed within this list.
I would appreciated any hint.
Thanks Timothy
Re: [Acceleo] Arguments list in Generator-API [message #498707 is a reply to message #498694] |
Wed, 18 November 2009 04:43  |
--------------090709070609070806090301
Hi Timothy,
Please use the m2t forum (added to the cc list of this reply) for
questions on Acceleo.
As for your question; "the Accelo.doGenerate-API [...] what can be
passed as arguments? [...] what should be passed within this list" ...
arguments to what? Which list?
I can see only one "doGenerate(...)" method in the AcceleoService class
(hope this is what you meant by "Acceleo") that takes a "List" as
parameter : "public Map<String, String> doGenerate(Module, String,
EObject, List<? extends Object>, File, Monitor)", I'll assume you were
talking about that one. Though if the javadoc
----------8<----------
This is a convenience method that can be used with multiple argument
templates. The input model will be iterated over for objects matching
the template's <b>first</b> parameter type. The template will then be
called with these objects as first arguments, and the given list of
<code>arguments</code> for the remaining template parameters.
@param arguments
Arguments of the template call, excluding the very first one
(<code>model</code> object).
---------->8----------
doesn't help you, I don't really know how I can. For example, if your
template is defined as
[module MyModule(...)/]
[template generate(c : EClass, s : String)]
Then to call this template on all "EClass"es of model "myModel.ecore"
with argument "s" equal to "testString" you have to call
AcceleoService.doGenerate(...) as :
File generationRoot = new File("project/src-gen");
Module myModule = ...;
String templateName = "generate";
EObject model = ModelUtils.load("myModel.ecore");
List<Object> args = new ArrayList<Object>();
args.add("testString");
AcceleoService.doGenerate(myModule, "generate", model, args,
generationRoot, new BasicMonitor());
Laurent Goubet
Obeo
Timothy Marc wrote:
> Hi all,
> Thanks Timothy
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------090709070609070806090301--
Re: [Acceleo] Arguments list in Generator-API [message #621595 is a reply to message #498694] |
Hi Timothy,
@param arguments
Laurent Goubet
Obeo
Timothy Marc wrote:
> Hi all,
> Thanks Timothy
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
Current Time: Wed Jul 23 17:01:46 EDT 2025
Powered by FUDForum. Page generated in 0.03733 seconds
