Home » Modeling » Epsilon » Different diagram for one metamodel (ex Architectural and Type Diagram)
Different diagram for one metamodel (ex Architectural and Type Diagram) [message #498678] |
Tue, 17 November 2009 21:46  |
hi
I have the following file annotated EMF.
@namespace(uri="http://a0.ecore", prefix="A0")
@gmf(foo="bar")
package A0;
@namespace(uri="core", prefix="core")
package core {
class SAComponent extends Component {
@gmf.node(figure="rounded",label="name")
class SAConnector extends Component {
@gmf.node(figure="a0_editor.diagram.figures.TypeFigure",label= "name")
class Type extends PropertyHolderElement {
@gmf.link(color="250,100,100")
ref TypedElement[*]#type implementations;
ref Type[*]#subtypes supertypes;
@gmf.link(color="50,200,100",target.decoration="closedarrow ")
ref Type[*]#supertypes subtypes;
@gmf.node(figure="rounded",label = "name")
class SAInterface extends InteractionPoint, ArchitecturalElement {
attr SAInterfaceDirection direction;
val Behavior[*] behavior;
@gmf.node(figure="rectangle",label="name")
abstract class Component extends ConnectableElement, ArchitecturalElement {
@gmf.compartment(foo="bar", collapsible="true")
val ArchitecturalElement[*] subElement;
@gmf.link(style="solid", width="2")
class SAChannel extends SARelationship {
abstract class Behavior extends Element {
abstract class Business extends Element {
abstract class Development extends Element {
abstract class Element {
attr String name;
attr String description;
val Development development;
val Business business;
@gmf.link(source="from",target="to",label="name")
abstract class Link extends PropertyHolderElement, TypedElement {
attr LinkNavigability navigability;
ref ConnectableElement[1] from;
ref ConnectableElement[1] to;
ref Component fromContext;
ref Component toContext;
abstract class ConnectableElement extends Element {
@gmf.node(figure="rounded", label="name")
abstract class TypedElement extends Element {
ref Type[*]#implementations type;
abstract class PropertyHolderElement extends Element {
val Property[*] properties;
@gmf.node(label="name,type,value", figure="rectangle", label.pattern="{1} {0} : {2}")
class Property extends Element {
attr PropertyType type;
attr String value;
enum SAInterfaceDirection {
input = 0;
output = 1;
inputOutput = 2;
@gmf.node(figure="rectangle", size="20,20", label="name",
label.placement="external", label.icon="false")
abstract class InteractionPoint extends ConnectableElement {
enum LinkNavigability {
bidirectional = 0;
unidirectional = 1;
@gmf.link(target.decoration="arrow",style="dash")
class SARelationship extends Link, ArchitecturalElement {
abstract class Architecture extends PropertyHolderElement {
val Group[*] groups;
@gmf.diagram (foo="bar")
class SoftwareArchitecture extends Architecture {
abstract class ArchitecturalElement extends PropertyHolderElement, TypedElement {
@gmf.node(figure="ellipse",label = "name")
class Group extends Element {
@gmf.link(style="dot",tool.small.path="/a0_editor.edit/icons/full/obj16/Members.gif ",tool.large.path="/a0_editor.edit/icons/full/obj16/Members.gif ")
ref Element[*] members;
@gmf.node(figure="a0_editor.diagram.figures.TypesSpecificationFigure ")
class TypesSpecification {
@gmf.compartment(foo="bar", collapsible="false")
val Type[*] types;
class SAType extends Type {
enum PropertyType {
string = 0;
int = 1;
boolean = 2;
reference = 3;
float = 4;
double = 5;
short = 6;
long = 7;
any = 8;
class SAStructuredType extends SAType {
@gmf.compartment(collapsible="false")
@gmf.link(style="solid")
class SABinding extends SARelationship {
I wanted to know if by Eugenia I can create two different diagram, since there is the possibility of using one gmf.diagram ...
wish I could manage the architectural elements in a diagram and types to another diagram.
I would like to define two different palette with controls for the items associated with the particular diagram.
I wish that there be a connection between the two diagrams.
For example if I create a new type I wish associate it to an element defined in the architectural diagram.
How can I accomplish this? Knows someone give me a hint?
I tried to follow these two posts, but I did not understand much and I do not think are compatible with the use of Eugenia.
http://wiki.eclipse.org/Diagram_Partitioning
http://wiki.eclipse.org/GMF_Tips#Sharing_single_EditingDomai n_instance_across_several_diagrams
regards
marco
Re: Different diagram for one metamodel (ex Architectural and Type Diagram) [message #498708 is a reply to message #498678] |
Wed, 18 November 2009 04:51  |
Hi Marco,
Eugenia doesn't support diagram partitioning yet but it's in our plans
to add this feature. Please CC yourself
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295271 to keep track of
any progress on this.
Dimitris
marco wrote:
> hi
> @gmf(foo="bar")
> package A0;
> package core {
> @gmf.link(color="250,100,100") ref TypedElement[*]#type
> implementations;
> attr String name;
> attr String value;
> input = 0;
> output = 1;
> inputOutput = 2;
> bidirectional = 0;
> unidirectional = 1;
> TypedElement {
> val Type[*] types;
> enum PropertyType {
> string = 0;
> int = 1;
> boolean = 2;
> reference = 3;
> float = 4;
> double = 5;
> short = 6;
> long = 7;
> any = 8;
> another diagram.
> regards marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Current Time: Wed Jul 23 04:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.08432 seconds
