Home » Modeling » EMF » [Teneo] sdo serialization and equality with idbag or index
| [Teneo] sdo serialization and equality with idbag or index [message #498560] |
Tue, 17 November 2009 08:58  |
Hi all,
I have had problem of deadlock with a simple n:m relation.
I have understood that it was probably because of that I declare no
index or idbag on my relation, and so on each change hibernate remove
several entries to reinsert those not really removed.
So I am trying to use idbag or index and I have problem of equality of
this object after a serialization-deserialization (it worked well before)
We are using Teneo 1.1.0 / EMF 2.4.3 and sdo serialization.
The method to test the equality is EcoreUtil.equals
Is this kind of problem is telling you something ?
What can I do to find a solution to my problem.
Thanks for your help.
Thomas
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498592 is a reply to message #498561] |
Tue, 17 November 2009 10:36   |
It is on the method
public boolean equals(EObject eObject1, EObject eObject2)
on these return:
// Both eObject1 and eObject2 are not null.
// If eObject1 has been compared already...
Object eObject1MappedValue = get(eObject1);
if (eObject1MappedValue != null)
// Then eObject2 must be that previous match.
return eObject1MappedValue == eObject2;
Here is the thread stack
Thread [Main Thread] (Suspended)
EcoreUtil$EqualityHelper.equals(EObject, EObject) line: 2122
EcoreUtil$EqualityHelper.haveEqualReference(EObject, EObject,
EReference) line: 2246
EcoreUtil$EqualityHelper.haveEqualFeature(EObject, EObject,
EStructuralFeature) line: 2226
EcoreUtil$EqualityHelper.equals(EObject, EObject) line: 2171
EcoreUtil$EqualityHelper.equals(List<EObject>, List<EObject>) line: 2202
EReference) line: 2245
EcoreUtil.equals(EObject, EObject) line: 2047
BasicSerializationTest.testSerializeResource() line: 88
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 585
TestMethod.invoke(Object) line: 59
MethodRoadie.runTestMethod() line: 98
MethodRoadie$2.run() line: 79
MethodRoadie.runBeforesThenTestThenAfters(Runnable) line: 87
MethodRoadie.runTest() line: 77
MethodRoadie.run() line: 42
JUnit4ClassRunner.invokeTestMethod(Method, RunNotifier) line: 88
JUnit4ClassRunner.runMethods(RunNotifier) line: 51
JUnit4ClassRunner$1.run() line: 44
ClassRoadie.runUnprotected() line: 27
ClassRoadie.runProtected() line: 37
JUnit4ClassRunner.run(RunNotifier) line: 42
JUnit4TestMethodReference(JUnit4TestReference).run(TestExecu tion) line: 46
TestExecution.run(ITestReference[]) line: 38
RemoteTestRunner.runTests(String[], String, TestExecution) line: 467
RemoteTestRunner.runTests(TestExecution) line: 683
RemoteTestRunner.run() line: 390
RemoteTestRunner.main(String[]) line: 197
Martin Taal a écrit :
> Hi Thomas,
> I am afraid that it does not directly ring a bell with me. Can you
> create a small testmodel which reproduces the issues?
> Also on what check does the equality fail (in EcoreUtil.EqualityHelper?
> gr. Martin
> Thomas Franconville wrote:
>> Hi all,
>> Regards
>> Thomas
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498594 is a reply to message #498592] |
Tue, 17 November 2009 10:46   |
I have found where it is coming from.
I have overridden methods equals and hashcode for another problem
* @generated NOT
public int hashCode()
if(id == null)
return super.hashCode();
else
return id.hashCode();
* @generated NOT
public boolean equals(Object obj)
if (this == obj)
return true;
if (obj == null)
return false;
if (!(obj instanceof SubActivityImpl))
return false;
SubActivityImpl other = (SubActivityImpl) obj;
if (id == null)
if (other.id != null)
return false;
else
return super.equals(obj);
else if (!id.equals(other.id))
return false;
return true;
Id is a String which is our key.
Without those method, I have this Exception:
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(ArrayList.java:546)
at java.util.ArrayList.get(ArrayList.java:321)
at org.hibernate.collection.PersistentBag.get(PersistentBag.jav a:423)
at
org.eclipse.emf.common.util.DelegatingEList.delegateGet(Dele gatingEList.java:407)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eGet(PersistableEList.java:399)
at
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)
at
com.oslo.dreams.model.impl.SaveAssignedTest.testSaveAssigned ResourcesOnSubActivitiesWithData(SaveAssignedTest.java:486)
Thomas Franconville a écrit :
> It is on the method
> on these return:
> 2202
> line: 46
>> Hi Thomas,
>> gr. Martin
>>> Hi all,
>>> of this object after a serialization-deserialization (it worked well
>>> before)
>>> Regards
>>> Thomas
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498602 is a reply to message #498594] |
Tue, 17 November 2009 11:16   |
It's ok. I have found the problem and a work around.
So, what I am doing in this test, is to create an object and the
association (where I need the idbag or index)
I am doing then a query on these object, and the object returned has an
empty list. if I do a refresh on it, the list is filled.
It is quite stange as it works if there is no idbag or index and data
are in the object use to create/store in database, and are well stored.
> * @generated NOT
> @Override
> if(id == null)
> else
> * @generated NOT
> @Override
> if (this == obj)
> return true;
> if (obj == null)
> return false;
> return false;
> if (id == null)
> return false;
> else
> return false;
> return true;
> at
> at
> at
> at
>> It is on the method
>> on these return:
>> 2202 EcoreUtil$EqualityHelper.haveEqualReference(EObject,
>> EObject, EReference) line: 2245
>> TestMethod.invoke(Object) line: 59 MethodRoadie.runTestMethod()
>> line: 98 MethodRoadie$2.run() line: 79
>> MethodRoadie.runTest() line: 77 MethodRoadie.run() line: 42
>> JUnit4ClassRunner$1.run() line: 44 ClassRoadie.runUnprotected()
>> line: 27 ClassRoadie.runProtected() line: 37
>> line: 46 TestExecution.run(ITestReference[]) line: 38
>> RemoteTestRunner.run() line: 390 RemoteTestRunner.main(String[])
>> line: 197
>>> Hi Thomas,
>>> gr. Martin
>>>> Hi all,
>>>> remove several entries to reinsert those not really removed.
>>>> before)
>>>> Regards
>>>> Thomas
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498621 is a reply to message #498602] |
Tue, 17 November 2009 12:14   |
Hi Thomas,
It still sounds a bit strange... It is possible that the EqualHelper tests something on the list which does not force
the list to be loaded (while it should), could that be the case?
What do you mean with refresh the object/list?
gr. Martin
>> * @generated NOT
>> @Override
>> if(id == null)
>> else
>> return id.hashCode(); }
>> * @generated NOT
>> @Override
>> if (this == obj)
>> return true;
>> if (obj == null)
>> return false;
>> return false;
>> if (id == null)
>> return false;
>> else
>> return false;
>> return true;
>> at
>> at
>> at
>> at
>>> It is on the method
>>> on these return:
>>> 88 JUnit4ClassRunner.runMethods(RunNotifier) line: 51
>>> 467 RemoteTestRunner.runTests(TestExecution) line: 683
>>>> Hi Thomas,
>>>> gr. Martin
>>>>> Hi all,
>>>>> well before)
>>>>> Regards
>>>>> Thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498718 is a reply to message #498621] |
Wed, 18 November 2009 05:41   |
Hi Martin,
What is strange is that ever in a debug mode, when I read the list, the
debugger doesn't try to lazy load the relation and the list is well a
HibernatePersistentEList
I mean by refresh the object, I do a entityManager.refresh(myObject)
where myObject is the containing object.
> Hi Thomas,
> tests something on the list which does not force the list to be loaded
> gr. Martin
>> an empty list. if I do a refresh on it, the list is filled.
>>> * @generated NOT
>>> @Override
>>> if(id == null)
>>> else
>>> * @generated NOT
>>> @Override
>>> if (this == obj)
>>> return true;
>>> if (obj == null)
>>> return false;
>>> return false;
>>> if (id == null)
>>> return false;
>>> else
>>> return false;
>>> return true;
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> It is on the method
>>>> on these return:
>>>> MethodRoadie.runTestMethod() line: 98 MethodRoadie$2.run()
>>>> line: 79 MethodRoadie.runBeforesThenTestThenAfters(Runnable)
>>>> line: 87 MethodRoadie.runTest() line: 77
>>>> RemoteTestRunner.main(String[]) line: 197 Martin Taal a écrit :
>>>>> Hi Thomas,
>>>>> gr. Martin
>>>>>> Hi all,
>>>>>> no index or idbag on my relation, and so on each change hibernate
>>>>>> equality of this object after a serialization-deserialization (it
>>>>>> worked well before)
>>>>>> Regards
>>>>>> Thomas
| Re: [Teneo] sdo serialization and equality with idbag or index [message #498720 is a reply to message #498718] |
Wed, 18 November 2009 06:23  |
Hi Thomas,
Yes indeed strange, it would be great if you can create a small test model/case which replicates the behavior...
gr. Martin
> Hi Martin,
>> Hi Thomas,
>> gr. Martin
>>>> * @generated NOT
>>>> @Override
>>>> if(id == null)
>>>> else
>>>> * @generated NOT
>>>> @Override
>>>> if (this == obj)
>>>> return true;
>>>> if (obj == null)
>>>> return false;
>>>> return false;
>>>> if (id == null)
>>>> return false;
>>>> else
>>>> return false;
>>>> return true;
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> It is on the method
>>>>> on these return:
>>>>> not available [native method]
>>>>> 25 Method.invoke(Object, Object...) line: 585
>>>>>> Hi Thomas,
>>>>>> gr. Martin
>>>>>>> Hi all,
>>>>>>> worked well before)
>>>>>>> Regards
>>>>>>> Thomas
The Netherlands
Current Time: Sat Nov 08 04:33:17 EST 2025
Powered by FUDForum. Page generated in 0.06803 seconds
