Home » Modeling » Epsilon » EVL validation is working, EMF is not
EVL validation is working, EMF is not [message #498522] |
Tue, 17 November 2009 05:43  |
Hi all,
I've implemented EVL validation in my GMF application, I've difined my own rules in *.evl file in an external plugin (as I read in http://www.eclipse.org/gmt/epsilon/doc/articles/evl-gmf-inte gration/ ): it's working fine, but on my console i got the following:
at org.eclipse.epsilon.emc.emf.EmfUtil.getEStructuralFeature(Em fUtil.java:50)
at org.eclipse.epsilon.emc.emf.AbstractEmfModel.knowsAboutPrope rty(AbstractEmfModel.java:137)
and the rules implemented at EMF Model level are not respected; anyone knows about that problem?
Giovanni.
Re: EVL validation is working, EMF is not [message #498924 is a reply to message #498527] |
Thu, 19 November 2009 03:42   |
Sure, this is my environment:
- Eclipse Modeling Galileo SR1 Incubation
- Epsilon (by stable update site)
- EMFatic
I developed a new GMF Project from an *.emf file:
@namespace(uri="hierarchy", prefix="hierarchy")
@gmf(foo="bar")
package hierarchy;
@gmf.link(source="From",target="To",style="solid",width= "1",label.icon="false",tool.small.path="icons\obj16\Association.gif ",tool.small.bundle="org.eclipse.uml2.diagram.common")
class Arc {
ref Node[1]#arcs From;
ref Node[1] To;
id attr String name;
attr boolean[1] multiple = false;
attr boolean[1] optional = false;
@gmf.node(figure="ellipse",size="15,15",color="0,0,0",tool.small.path= "icons\obj16\ActivityFinalNode.gif",tool.small.bundle="org.eclipse.uml2.diagram.common ")
class Dimension extends Node {
@gmf.node(figure="ellipse",size="10,10",tool.small.path= "icons\obj16\Artifact.gif",tool.small.bundle="org.eclipse.uml2.diagram.common ")
class Attribute extends Node {
attr boolean[1] crossDimensional = false;
attr boolean[1] descriptive = false;
attr boolean[1] convergence = false;
attr boolean[1] shared = false;
attr boolean[1] recursive = false;
@gmf.diagram(onefile="true",model.extension="hrc",diagram.extension= "hrc")
class Hierarchy {
id attr String[1] name;
val Dimension[1] dimension;
val Attribute[*] attributes;
attr String description;
attr String businessDescription = "";
attr Date dateLastModified;
attr Date date;
attr Type type = "NOT_CONFORMED";
val FactSchema factSchema;
@gmf.node(label="name",label.placement="external",label.icon= "false")
abstract interface Node {
attr String businessDescription;
attr Date date;
attr DataType dataType;
val Arc[*]#From arcs;
datatype Date : java.util.Date;
enum Type {
CONFORMED = 0;
NOT_CONFORMED = 1;
DEGENERATED = 2;
enum DataType {
CHAR = 0;
VARCHAR = 1;
TEXT = 2;
INTEGER = 3;
FLOAT = 4;
@gmf.node(label="name",label.placement="internal",figure= "rounded",size="60,90",tool.small.path="icons\obj16\ActivityPartition.gif ",tool.small.bundle="org.eclipse.uml2.diagram.common")
class FactSchema extends Node {
@gmf.compartment(layout="list")
val Measure[+] measures;
@gmf.node(label="name",label.icon="false",label.placement= "internal",figure="rectangle",size="60,25",tool.small.path= "icons\obj16\ActivityParameterNode.gif",tool.small.bundle="org.eclipse.uml2.diagram.common ")
class Measure {
attr Date date;
attr boolean ~derived;
attr String formula = "";
and thus I added a validation plugin with an *.evl file with several rules, that are respected when I invoke "Validate" from the menu of my application. But the implicit constraint derived from EMF model (i.e.: at least one Dimensione per Hierarchy, or every Object must have a name, ....) are not validated.
Instead, the NullPointerException was resolved, the cause was an error in the *.evl file synthax.
Re: EVL validation is working, EMF is not [message #498963 is a reply to message #498924] |
Thu, 19 November 2009 05:52   |
Hi Giovanni,
I've reproduced this and it seems to be a bug. Could you please open a
bug report and post the link here?
Dimitris
> - EMFatic
> @gmf(foo="bar")
> package hierarchy;
> class Arc {
> ref Node[1] To;
> class Hierarchy {
> attr Date date;
> attr Date date;
> enum Type {
> CONFORMED = 0;
> NOT_CONFORMED = 1;
> DEGENERATED = 2;
> enum DataType {
> CHAR = 0;
> VARCHAR = 1;
> TEXT = 2;
> INTEGER = 3;
> FLOAT = 4;
> class Measure {
> attr Date date;
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: EVL validation is working, EMF is not [message #583010 is a reply to message #498527] |
- EMFatic
@gmf(foo="bar")
package hierarchy;
class Arc {
ref Node[1] To;
class Hierarchy {
attr Date date;
attr Date date;
enum Type {
CONFORMED = 0;
NOT_CONFORMED = 1;
DEGENERATED = 2;
enum DataType {
CHAR = 0;
VARCHAR = 1;
TEXT = 2;
INTEGER = 3;
FLOAT = 4;
class Measure {
attr Date date;
Re: EVL validation is working, EMF is not [message #583024 is a reply to message #583010] |
Hi Giovanni,
Dimitris
> - EMFatic
> @gmf(foo="bar")
> package hierarchy;
> class Arc {
> ref Node[1] To;
> class Hierarchy {
> attr Date date;
> attr Date date;
> enum Type {
> CONFORMED = 0;
> NOT_CONFORMED = 1;
> DEGENERATED = 2;
> enum DataType {
> CHAR = 0;
> VARCHAR = 1;
> TEXT = 2;
> INTEGER = 3;
> FLOAT = 4;
> class Measure {
> attr Date date;
Current Time: Sat Jul 26 01:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.04616 seconds
