query for class and interface check [message #498104] |
Sat, 14 November 2009 09:01  |
Originally posted by: formatzeh.gmx.de
I have a class WeaveMapping which consists of a Pointcut and an Advice.
Both have references to arbitrary other classes (source and target) in
the model. But I have to ensure that the referenced classes are from the
same type. This can be done by the following constraint:
self.pointcut.source.eClass() = self.advice.target.eClass()
But there is one shortcoming. In this way both classes only must have
the same type but not another implementation of an interface. For
example if there is an interface A in the model, having two
implementations B and C. If an instance B will be referenced as source
only another instance of B can be referenced as target. Is it possible
to specify a constraint allowing an instance of C as well? I can imagine
that it is a problem that all classes of a metamodel have the super
interface EObject. Means that the constraint must only allow interfaces
modeled by myself in the metamodel. Is it possible anyhow?
Re: query for class and interface check [message #498747 is a reply to message #498587] |
Wed, 18 November 2009 09:11  |
--=-NlzpDVK5wymtYkUjOsTc
Content-Type: text/plain
Hi, Gilbert,
EClass has always had an eSuperTypes property (I think that's the
spelling). It isn't actually an operation, as far as I recall. It
returns the direct super-eclasses, which may include "isAbstract" and
"isInterface" eclasses.
If you want to get all supertypes, unordered, a convenient way is
"eclass->closure(eSuperTypes)" assuming a variable named "eclass" of
type EClass.
To test for non-empty intersection, do eSuperTypes->asSet() on each
EClass and use the Set::intersection(Set(T)) operation. If you do a
transitive closure of super-types, then that is already a set.
HTH,
Christian
On Tue, 2009-11-17 at 16:03 +0100, Gilbert Mirenque wrote:
> > Since you are using eClass() you can probably use eSupertypes().
> does it return a set of all the super types? If yes, how can I find out
> if both set's have non-empty intersection?
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
EClass has always had an eSuperTypes property (I think that's the spelling). It isn't actually an operation, as far as I recall. It returns the direct super-eclasses, which may include "isAbstract" and "isInterface" eclasses.<BR>
<BR>
If you want to get all supertypes, unordered, a convenient way is "eclass->closure(eSuperTypes)" assuming a variable named "eclass" of type EClass.<BR>
<BR>
To test for non-empty intersection, do eSuperTypes->asSet() on each EClass and use the Set::intersection(Set(T)) operation. If you do a transitive closure of super-types, then that is already a set.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-NlzpDVK5wymtYkUjOsTc--
FUDForum. Page generated in 0.04129 seconds
