Home » Eclipse Projects » Subversive » Synchronize vs Populate in Synchronize view
Synchronize vs Populate in Synchronize view [message #498171] Sun, 15 November 2009 09:38 Go to next message
http://tinyurl.com/yk59woh
I want to ask you what is the difference between "Synchronize" and "Populate" in Team Synchronizing Perspective.
And What exactly is the check box - "Perform the chosen operation automatically on subsequent restarts", what are subsequent restarts ?
In help is anything about this.
Thank you
Re: Synchronize vs Populate in Synchronize view [message #498268 is a reply to message #498171] Mon, 16 November 2009 04:32 Go to previous messageGo to next message
Hello sNop,
You have to see following description in Sync View:
"This view is not populated on startup. You can choose to populate without
contacting the server or to synchronize with the server."
"Synchronize" means that you contact the server to show Sync view content.
"Populate" means that in order to show Sync view content there's not
contacting the server, it uses previous (before restart) Sync view content,
i.e. Sync view content was persisted and after Eclipse restart it's just
loaded.
Restarts of Eclipse.
From quick search I also didn't find any help on it too, probably Team
developers thought that it should be clear from description "This view is
not populated on startup ..."; but if you find it as not understandable you
can fire a bug on Team component about it.
> Thank you
Re: Synchronize vs Populate in Synchronize view [message #498341 is a reply to message #498268] Mon, 16 November 2009 09:17 Go to previous message
Igor Burilo napsal(a):
> Hello sNop,
> loaded.
Thank you it's clear now
Previous Topic:Re: Does scheduled synchronize work?
Next Topic:Setting depth of working copy
Current Time: Sat Jul 26 19:23:05 EDT 2025
Powered by FUDForum. Page generated in 0.24269 seconds
