Home » Modeling » M2T (model-to-text transformation) » XPAND and XSD adapter(namespace problem)
XPAND and XSD adapter [message #498084] Sat, 14 November 2009 06:31 Go to next message
To isolate a problem with namespace I created a minimalistic project, and now even without namespace. And it seems that suddenly nothing works anymore.
The template editor shows errors for all types and elements that they are not resolvable. But the Reader can read the xml and the Generator processes the first 2 elements (root and entity) but then fails with TheName of entity.
INFO: Loading XSDSchema from 'ns1.xsd'
Nov 14, 2009 12:09:04 PM org.eclipse.xtend.typesystem.xsd.builder.OawXSDEcoreBuilder initEPackage
INFO: Creating EPackage 'ns1' from XSDSchema 'file:/.../ns1.xsd' (null)
Nov 14, 2009 12:09:05 PM org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: XMLReader: Loading XML file entity.xml
INFO: DirectoryCleaner: cleaning directory 'src-gen/mypackage'
INFO: Generator: generating 'templates::main::Root FOR model' => src-gen
Nov 14, 2009 12:09:05 PM org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflo wComponent invokeInternal
SEVERE: Error in Component of type org.eclipse.xpand2.Generator:
EvaluationException : Couldn't find type or property 'TheName'
templates::main.xpt[162,7] on line 11 'TheName'
templates::main.xpt[75,28] on line 6 'EXPAND entity FOREACH entity'
[23,38] on line 1 'EXPAND templates::main::Root FOR model'
For easy reproducing I have uploaded the project to http://drop.io/9t38ntm
Most probably I am blind again. This project is so simple and still I can't see what is wrong.
br,
Marco
Re: XPAND and XSD adapter [message #498091 is a reply to message #498084] Sat, 14 November 2009 07:00 Go to previous messageGo to next message
hi, the problem is quite simple to solve:
modify the template like this
«DEFINE entity FOR EntityType»
	«theName.value»
«ENDDEFINE»
by the way. it helps you if you put your metamodel into a source folder and enable the xsd metamodels in the xtend/xpand section of your projects preferences. then you'll get e.g. code completion in your templates
Re: XPAND and XSD adapter [message #498093 is a reply to message #498091] Sat, 14 November 2009 07:15 Go to previous messageGo to next message
Thank you Christian.
Now I have re-introduced the namespace in the XSD and get the following error which is the same as in my real project:
	EvaluationException : No Definition 'templates::main::Root for type::AnyType' found!
ns1.xsd
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" targetNamespace="http://www.example.org/test" xmlns:ns1="http://www.example.org/test">
  <xs:element name="root">
    <xs:complexType>
      <xs:sequence>
        <xs:element maxOccurs="unbounded" ref="ns1:Entity"/>
      </xs:sequence>
    </xs:complexType>
  </xs:element>
  <xs:element name="Entity">
    <xs:complexType>
      <xs:sequence>
        <xs:element ref="ns1:TheName"/>
      </xs:sequence>
    </xs:complexType>
  </xs:element>
  <xs:element name="TheName">
    <xs:complexType>
      <xs:simpleContent>
        <xs:extension base="xs:NCName">
          <xs:attribute name="Type" use="required" type="xs:NCName"/>
        </xs:extension>
      </xs:simpleContent>
    </xs:complexType>
  </xs:element>
</xs:schema>
br
Marco
Re: XPAND and XSD adapter [message #498095 is a reply to message #498093] Sat, 14 November 2009 07:45 Go to previous message
as you can find in the documentation and maybe already tried <option key="DEFAULT_NAMESPACE" val="http://www.example.org/test" /> does the trick
Previous Topic:XSD adapter and imports
Next Topic:Doubt in Xpand template
Current Time: Fri Sep 19 08:54:53 EDT 2025
Powered by FUDForum. Page generated in 0.66788 seconds
