Home » Eclipse Projects » Rich Client Platform (RCP) » How to set the editor title?
How to set the editor title? [message #498014] Fri, 13 November 2009 12:01 Go to next message
hi everybody,
I have a view and an editor. in the view is a tableviewer which shows all the data of my xmi-model. if i doubleclick on it, the editor will open with the description of the selected item.
So my problem is, i want to set the title with the name of the item. how can i implement it?
the default title of this editor can i set in the plugin.xml.
please help
greetz d.chau
Re: How to set the editor title? [message #498035 is a reply to message #498014] Fri, 13 November 2009 13:20 Go to previous messageGo to next message
normally you would use your editorinput for this?
Martin
Re: How to set the editor title? [message #498045 is a reply to message #498014] Fri, 13 November 2009 15:36 Go to previous messageGo to next message
hi martin,
yeah the selected item on the tableviewer will give as editorinput to the page.openEditor. but the title for the selected item is not setted on the editor title.
Re: How to set the editor title? [message #498062 is a reply to message #498014] Fri, 13 November 2009 19:21 Go to previous messageGo to next message
Originally posted by: wangqs_eclipse.yahoo.com
--------------010006090108020402030403
Try this method.
EditorPart:setPartName(String partName)
Q.S. Wang
Chau wrote:
> hi everybody,
> can i implement it?
> please help
> greetz d.chau
name="wangqs_eclipse.vcf"
filename="wangqs_eclipse.vcf"
YmVnaW46dmNhcmQNCmVtYWlsO2ludGVybmV0Ondhbmdxc19lY2xpcHNlQHlh aG9vLmNvbQ0K
dXJsOmh0dHA6Ly93d3cubXllY2xpcHNlZGV2LmNvbQ0KdmVyc2lvbjoyLjEN CmVuZDp2Y2Fy
ZA0KDQo=
--------------010006090108020402030403--
Re: How to set the editor title? [message #498079 is a reply to message #498014] Sat, 14 November 2009 05:36 Go to previous messageGo to next message
hi eclipse user,
i tried this, it works but if i want to do this dynamic for the selected item, how can i do this?
because i implement and handler for the doubleclicking via extension points and the editor too.
so if i click on the item in the tableviewer the HandlerService starts and call the method
page.openEditor(input, MyEditor.ID);
and it set the default name in the plugin.xml. how can I set on this place the selected item name?
Re: Re: How to set the editor title? [message #498197 is a reply to message #498079] Sun, 15 November 2009 14:50 Go to previous messageGo to next message
Hi Chau,
It is like Q.S. Wang said. there is a method call setPartName(String). You
must call that in you init or wherever.
Wim Jongman
> hi eclipse user,
and the editor too.
call the method
Re: How to set the editor title? [message #498226 is a reply to message #498079] Sun, 15 November 2009 20:24 Go to previous message
Chau wrote:
> hi eclipse user,
> and call the method
Chau,
Well there's no guarantee, but at least AbstractTextEditor is using
input.getName as the title. Please try to return the description of the
item there in the getName() method if the input is written by you.
Q.S. Wang
http://www.myeclipsedev.com/
Previous Topic:I dont know how to use the IProgressMonitor stop button :(
Next Topic:How to set an editor unmodifiable?
Current Time: Sat Jul 26 08:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.04413 seconds
