Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table ScrollBar missing in GridLayout and Rowlayout(ScrollBar does not appear in tables for GridLayout. and RowLayout while it appears for FillLayout)
Table ScrollBar missing in GridLayout and Rowlayout [message #497094] Thu, 12 November 2009 08:59 Go to next message
The scroll bar does not appear for the tables in the code below for GridLayout and RowLayout. However it appears for FillLayout.
I want it to appear for GridLayout.
The code is as follows:
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowData;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.ScrollBar;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class MatrixView {
public MatrixView() {
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
// uncommenting line below will make scroll bar appear
//shell.setLayout(new FillLayout());
/*RowLayout rowLayout = new RowLayout();
rowLayout.wrap = false;
shell.setLayout(rowLayout);*/
GridLayout gridLayout = new GridLayout();
gridLayout.numColumns = 2;
gridLayout.marginWidth = 1;
shell.setLayout(gridLayout);
final ScrolledComposite sc1 = new ScrolledComposite (shell,
SWT.H_SCROLL
| SWT.V_SCROLL);
final ScrolledComposite sc2 = new ScrolledComposite (shell,
SWT.H_SCROLL
| SWT.V_SCROLL);
Table table1 = new Table(sc1,SWT.SINGLE);
table1.setHeaderVisible(false);
table1.setLinesVisible(true);
TableColumn col1 = new TableColumn(table1,SWT.LEFT);
col1.setWidth(200);
TableColumn col2 = new TableColumn(table1,SWT.LEFT);
col2.setWidth(60);
for (int i = 0; i < 60; i++) {
TableItem item1 = new TableItem(table1,0);
item1.setText(new String[]{"Line " + i,"b"});
Table table2 = new Table(sc2,SWT.SINGLE);
table2.setHeaderVisible(false);
table2.setLinesVisible(true);
for (int i = 0; i < 10; i++) {
TableColumn col21 = new TableColumn(table2,SWT.LEFT);
col21.setWidth(80);
TableItem item1 = new TableItem(table2,0);
item1.setText(new String[]{"Line "+i,"c"});
sc1.setContent(table1);
table1.pack();
sc2.setContent(table2);
table2.pack();
System.out.println("Show");
shell.setSize (500, 500);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Any help will be appreciated.
Sajit
Re: Table ScrollBar missing in GridLayout and Rowlayout [message #497998 is a reply to message #497094] Fri, 13 November 2009 11:08 Go to previous messageGo to next message
Hi Sajit,
Here's your snippet with a few changes to show scrollbars with GridLayout:
Display display = new Display();
Shell shell = new Shell(display);
// shell.setLayout(new FillLayout());
* RowLayout rowLayout = new RowLayout(); rowLayout.wrap = false;
* shell.setLayout(rowLayout);
GridLayout gridLayout = new GridLayout(2, true);
final ScrolledComposite sc1 = new ScrolledComposite(shell, SWT.H_SCROLL
| SWT.V_SCROLL | SWT.BORDER);
final ScrolledComposite sc2 = new ScrolledComposite(shell, SWT.H_SCROLL
Table table1 = new Table(sc1, SWT.SINGLE);
TableColumn col1 = new TableColumn(table1, SWT.LEFT);
col1.setWidth(200);
TableColumn col2 = new TableColumn(table1, SWT.LEFT);
col2.setWidth(60);
TableItem item1 = new TableItem(table1, 0);
item1.setText(new String[] { "Line " + i, "b" });
Table table2 = new Table(sc2, SWT.SINGLE);
TableColumn col21 = new TableColumn(table2, SWT.LEFT);
col21.setWidth(80);
TableItem item1 = new TableItem(table2, 0);
item1.setText(new String[] { "Line " + i, "c" });
sc1.setLayoutData(new GridData(GridData.FILL_BOTH));
sc2.setLayoutData(new GridData(GridData.FILL_BOTH));
table1.pack();
table2.pack();
shell.setSize(500, 500);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Sajit" <catchpiscean@rediffmail.com> wrote in message
news:hdh4ba$qmh$1@build.eclipse.org...
> import org.eclipse.swt.widgets.Display;
> SWT.H_SCROLL
> | SWT.V_SCROLL);
> SWT.H_SCROLL
> | SWT.V_SCROLL);
> col1.setWidth(200);
> col2.setWidth(60);
> col21.setWidth(80);
> table1.pack();
> table2.pack();
> shell.open ();
> display.dispose ();
> Sajit
Re: Table ScrollBar missing in GridLayout and Rowlayout [message #838246 is a reply to message #497998] Fri, 06 April 2012 15:49 Go to previous message
    // parent code her ...
         final ScrolledComposite scrolledComposite = new ScrolledComposite(shell, SWT.BORDER | SWT.V_SCROLL);
              composite = new Composite(scrolledComposite, SWT.NONE);
              composite.setBounds(0, 0, 300, 200);
              composite.setBackground(ResourceManager.getColor(SWT.COLOR_CYAN));
              scrolledComposite.setContent(composite);
                 final Button button = new Button(composite, SWT.NONE);
                 button.setBounds(150, 115, 60, 35);
                 button.setText("button");
    // and AFTER! everything had been set, we do a:
    composite.setSize(composite.computeSize(SWT.DEFAULT, SWT.DEFAULT));
Previous Topic:How to handle unsupported data type when calling java script function using SWT Browser
Next Topic:Dynamic 32-64 bit loading
Current Time: Sat Jul 26 11:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.24829 seconds
