Applying stereotype programmatically fails [message #497167] |
Thu, 12 November 2009 12:38  |
I am doing my first UML profile.
Following the article 'Introduction to UML2 Profiles', I tried everything manually. It all went fine, and the article was very useful.
Now when doing it programmatically, I am facing a problem when applying stereotype.
When the stereotype is applied, there is not exception, and everything seems to go fine - but on opening the .uml file in model editor, the stereotype is not there.
On close inspection I found that saving the model just before applying the stereotype, and after applying the stereotype resulted in no difference.
When I use this file (which has everything fine and in place, except the stereotype), and apply stereotype manually then on saving the content of .uml file change, and the entire uml:Model node becomes child of xmi:XMI node.
What am I missing?
.uml file start when stereotype was applied, but did not have any effect...
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_w25RsM-UEd6ARaBEQDTKaA" name="WWCUSTS">
<ownedComment xmi:id="_w25Rsc-UEd6ARaBEQDTKaA">
<body>WWCUSTS Model Comment</body>
</ownedComment>
<packagedElement xmi:type="uml:Package" xmi:id="_w25Rss-UEd6ARaBEQDTKaA" name="Types">
.uml file start when stereotype was applied manually, and resulted in changed xml structure...
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmlns:xanalysis="http:///schemas/xanalysis/_xm39IM-UEd6ARaBEQDTKaA/0" xsi:schemaLocation="http:///schemas/xanalysis/_xm39IM-UEd6ARaBEQDTKaA/0 file:/G:/vikram-admin/Documents/Adhoc/xanalysis.profile.uml#_yNeDEs-UEd6ARaBEQDTKaA">
<uml:Model xmi:id="_w25RsM-UEd6ARaBEQDTKaA" name="WWCUSTS">
</ownedComment>
Re: Applying stereotype programmatically fails [message #497177 is a reply to message #497167] |
Thu, 12 November 2009 13:20  |
Hi Vikram,
Set a breakpoint in StereotypeApplicationHelper.getContainmentList() and
double check that the proper resource is being used for the stereotype
application.
If everything seems fine there, I would suggest posting a small snippet of
code that demonstrates how you are applying the stereotype and saving the
file.
- James.
"Vikram" <vikram.sjn@gmail.com> wrote in message
news:hdhh68$ck0$1@build.eclipse.org...
> stereotype.
> node.
> What am I missing?
> </ownedComment>
> name="Types">
> file:/G:/vikram-admin/Documents/Adhoc/xanalysis.profile.uml# _yNeDEs-UEd6ARaBEQDTKaA ">
> </ownedComment>
FUDForum. Page generated in 0.05257 seconds
