Home » Eclipse Projects » Rich Client Platform (RCP) » Byte Order Mark ( BOM ) and Editor
Byte Order Mark ( BOM ) and Editor [message #496597] Tue, 10 November 2009 11:31 Go to next message
Hi!
I am working on an editor and have to edit files which could have a byte order mark at the beginning of the file. But I don't want the user to see the BOM and also the BOM must not be lost when the file is saved.
Could you give please give me a hint where to look and/or what to do?
Thanks in advance
Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #496724 is a reply to message #496597] Wed, 11 November 2009 02:26 Go to previous messageGo to next message
Andreas Winkler wrote:
> Hi!
> saved.
Simply use file buffers (see IFileBuffer) - they handle this
automatically for you.
Dani
> Thanks in advance
> Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #496910 is a reply to message #496724] Wed, 11 November 2009 12:15 Go to previous messageGo to next message
I extended AbstractDecoratedTextEditor with my editor and I thought it already uses FileBuffers?!
Maybe I have to set the FileBuffers somewhere to accept byte order mark?
Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #496993 is a reply to message #496910] Thu, 12 November 2009 02:02 Go to previous messageGo to next message
> Hi
Yes, it does. But of course the file has to have an encoding/charset
which has a BOM.
Dani
> Regards
> Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #497015 is a reply to message #496993] Thu, 12 November 2009 04:27 Go to previous messageGo to next message
But I thought the BOM indicates the charset/encoding?
That's why I am little confused, we use it to ensure that if another charset is used the editor recognises it and shows the correct text.
Do I have to tell the editor the file could have a UTF-8 encoding or UTF-16, or should FileBuffer already recognise this automatically and therefor doesn't show the BOM. If I have to tell the editor(FileBuffer) which encoding is "allowed" where do I have to put it? Is it a extension point?
Re: Byte Order Mark ( BOM ) and Editor [message #497022 is a reply to message #497015] Thu, 12 November 2009 04:48 Go to previous messageGo to next message
File buffers detect and preserve BOMs in existing files but when
creating files we don't add BOMs (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=78455).
Dani
Re: Byte Order Mark ( BOM ) and Editor [message #497036 is a reply to message #497022] Thu, 12 November 2009 05:51 Go to previous messageGo to next message
So far so good, but how do I tell my editor to not show the BOM?
Re: Byte Order Mark ( BOM ) and Editor [message #497040 is a reply to message #497036] Thu, 12 November 2009 06:05 Go to previous messageGo to next message
If it really uses file buffers underneath then the BOM is stripped and
should not appear in the editor.
org.eclipse.core.filebuffers.ITextFileBuffer.getDocument() should return
the file contents without the BOM.
Dani
Re: Byte Order Mark ( BOM ) and Editor [message #497049 is a reply to message #497040] Thu, 12 November 2009 06:33 Go to previous messageGo to next message
Thank you for your patience!
I don't get it then, I use IDE.openEditorOnFileStore( page, fileStore ); to send a file to my editor.
My Editor extends AbstractDecoratedTextEditor which should already use FileBuffers, at least that's what I thought.
In my editor i commented everything out so it doesn't do anything at the moment. But still I can see the BOM. That's why I am a little bit confused.
Have you any idea where I could look?
Thanks in advance
Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #497057 is a reply to message #497049] Thu, 12 November 2009 06:52 Go to previous messageGo to next message
OK, so you are not opening a workspace resource but an external file.
You might run into https://bugs.eclipse.org/bugs/show_bug.cgi?id=160614
then.
Dani
> confused.
> Thanks in advance
> Andreas
Re: Byte Order Mark ( BOM ) and Editor [message #497077 is a reply to message #497057] Thu, 12 November 2009 08:21 Go to previous message
Thank you for your help!
I found a solution even if I don't know if this is the best way Wink
I used the extension point org.eclipse.core.contenttype.contentTypes and made org.eclipse.core.runtime.text as base-type for my extensions. This seems to do the job.
Andreas
Previous Topic:Databinding Confusion
Next Topic:Binding a set of radio buttons to an int property
Current Time: Sat Jul 26 00:32:51 EDT 2025
Powered by FUDForum. Page generated in 0.25283 seconds
