Home » Modeling » Epsilon » Unable to run mergeoo example
Unable to run mergeoo example [message #496986] Thu, 12 November 2009 01:06 Go to next message
PROBLEM
When I run the mergeoo example I get the error message
Line: 5, Column: 4, Reason: mismatched input: 'with'
Line: 4, Column: 19, Reason: mismatched input 'Model' expecting NAME
WHAT I DID
- Eclipse 3.5, clean workspace
- Checked out all examples below
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/examples
- Registered all *.ecore in org.eclipse.epsilon.examples.metamodels
(right click + Register EPackages)
- In org.eclipse.epsilon.examples.mergeoo
- Right click on MergeOO.launch
- Run as -> MergeOO
- Result: Error message as pasted above
What am I missing? Any hints?
Goetz
Re: Unable to run mergeoo example [message #497017 is a reply to message #496986] Thu, 12 November 2009 04:30 Go to previous message
Hi Goetz,
Many thanks for reporting this! I've tidied up the example and committed
the changes (it was broken as a result of changing the role of "" in
0.8.8 - see
http://www.eclipse.org/gmt/epsilon/doc/articles/eol-syntax-u pdates/ for
more details on this).
Dimitris
Goetz Botterweck wrote:
> PROBLEM
> WHAT I DID
> - Run as -> MergeOO
> Goetz
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Unable to run mergeoo example [message #582714 is a reply to message #496986] Thu, 12 November 2009 04:30 Go to previous message
Hi Goetz,
0.8.8 - see
Dimitris
> PROBLEM
> WHAT I DID
> - Run as -> MergeOO
> Goetz
Previous Topic:Unable to run mergeoo example
Next Topic:EAnnotation details
Current Time: Wed Jul 23 18:33:55 EDT 2025
Powered by FUDForum. Page generated in 0.03771 seconds
