Re: Unhandled event loop exception [message #498166 is a reply to message #498097] |
Sun, 15 November 2009 07:37  |
hi, Benny,
Thanks for your suggestion! You give me the right direction. After removing org.eclipse.ui and org.eclipse.ui.workbench from the bundles list, my application works fine.
However, I still don't understand it well. With a clean Eclipse/RAP, I use the same launch config and the application runs fine. and 'ss' shows that both org.eclipse.ui and org.eclipse.ui.workbench are active. Why don't they cause trouble in this case?
besides, org.eclipse.ui and org.eclipse.ui.workbench are automatically added to the bundles list when I click the 'Add required bundles' button. isn't it misleading?
regards!
Jim
[Updated on: Sun, 15 November 2009 07:42] by Moderator
FUDForum. Page generated in 0.03178 seconds
