Home » Eclipse Projects » Eclipse Platform » Open File... menu command - get path of opened file(To get the file opened by the File Dialog in Open File... menu command)
Open File... menu command - get path of opened file [message #496059] Sat, 07 November 2009 13:00 Go to next message
I need to get the absolute path of the file which is opened by selecting through the File Open dialog via the menu command.
I am not able to get the same using the getEditorInput() function once it is loaded into the editor as this is a special file (.mdzip). Please find my related post reference for this as:
http://www.eclipse.org/forums/index.php?t=msg&goto=49549 2&S=9f327d5748b90cf305bfc6a31a16e637#msg_495492
So, I need to get file path information by hooking the Open File command somehow not from the editor. Is it possible to do the same. Any suggestions or other ways to achieve he same are always welcome.
Thanks in advance,
Abhinav
[Updated on: Sat, 07 November 2009 13:03] by Moderator
Re: Open File... menu command get path of file opened [message #496172 is a reply to message #496059] Mon, 09 November 2009 04:25 Go to previous messageGo to next message
Abhinav Mishra wrote:
> Please find my related post rference for this as:
Take a look at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.
Dani
> Thanks in advance,
> Abhinav
Re: Open File... menu command get path of file opened [message #496439 is a reply to message #496172] Tue, 10 November 2009 01:12 Go to previous messageGo to next message
hi Dani,
Thanks for the reply.
As per I have seen this, OpenLocalFileAction is used to programatically open any file in the Editor. But in my case, I need to open the file via Eclipse menu File->Open and get the value of selected filepath from the filedialog.i.e. I need to listen somehow for this action command.
Re: Open File... menu command get path of file opened [message #496455 is a reply to message #496439] Tue, 10 November 2009 03:10 Go to previous messageGo to next message
> hi Dani,
You need to provide your own action i.e. you can't modify or extend the
existing Open action.
Dani
Re: Open File... menu command get path of file opened [message #496474 is a reply to message #496455] Tue, 10 November 2009 04:10 Go to previous message
Hi Dani,
>You need to provide your own action i.e. you can't modify or >extend the existing Open action.
This is what I am doing right now. I've made a separate menu command like 'Open MDZIP File' and use this action.
This is working fine and I am able to get the filepath of MDZIP file.
But I need to do this without creating any new menu action i.e. existing Open File.. command.
Is it possible to do that way?
Previous Topic:Change cursor
Next Topic:Error decoration and custom overlay decoration
Current Time: Thu Jul 24 22:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.04186 seconds
