Home » Modeling » Epsilon » Showing EVL validation in "Problems" view: how to obtain it?
Showing EVL validation in "Problems" view: how to obtain it? [message #496258] |
Mon, 09 November 2009 09:23  |
Hi all,
I'm trying to reproduce EVL-GMF validation example: it works, I see the errors and warnings on my diagram surface, but I can't obtain validation errors and quick fix hint in my "Problems" view. I've added "org.eclipse.ui.views.ProblemView" in my DiagramEditorPerspective class by hand: is this wrong? What is the right way to do this?
Thanks in advance, regards
Giovanni.
Re: Showing EVL validation in "Problems" view: how to obtain it? [message #582629 is a reply to message #496271] |
Mon, 09 November 2009 10:08  |
The previous question was about how to DISPLAY the 'Problem' view in my Perspective, and it was resolved; now I have the problem on how to MAKE 'Problem' view WORKING: I have the validation enabled and working on diagram surface (with validation markers), but I can't see error and warning messages in my 'Problems' view, that remains blank.
Giovanni.
Re: Showing EVL validation in "Problems" view: how to obtain it? [message #582658 is a reply to message #496284] |
Mon, 09 November 2009 14:23  |
Hi Giovanni,
I've reproduced this but I'm not really sure how to overcome it. I
suspect the problems view displays markers of workspace resources but
since you're in RCP mode there's no such thing as a workspace.
I'll keep looking for a solution as this will be a good addition to the
EVL/GMF article. If you find any solution before I do, please report
back so that I can add it to the article for the benefit of other people
who may run across the same problem in the future.
Dimitris
Dimitris Kolovos wrote:
> Hi Giovanni,
> OK I see now. I'll have to investigate and get back to you.
> Cheers,
> Dimitris
>> Giovanni.
Current Time: Sat Jul 26 03:28:20 EDT 2025
Powered by FUDForum. Page generated in 0.29297 seconds
