Home » Archived » Riena » Java 5 Enums / Hessian / Riena
Java 5 Enums / Hessian / Riena [message #496232] Mon, 09 November 2009 07:28 Go to next message
I encountered a com.caucho.hessian.io.HessianFieldException when I tried to use a DTO which owns an Enum.
This is the Enum:
public enum BelegTyp {
	Lieferschein("LIEFERUNG"),
	Retoure("RETOURE"),
	Rechnung("REKO");
	private final static Map<String,BelegTyp> map = new HashMap<String,BelegTyp>();
	private final String value;
	private BelegTyp (String val){
		this.value = val;
	public String getValue() {
		return value;
	public String toString() {
		return value;
... this is the DTO which owns the Enum:
public class DTOBeleg {
	protected BelegTyp typ;
	public BelegTyp getTyp() {
		return typ;
	public void setTyp(BelegTyp typ) {
		this.typ = typ;
... and this is the DTO which has to be transferred:
public class DTOLieferschein extends DTOBeleg {
	private String lieferscheinNr;
	public String getLieferscheinNr() {
		return lieferscheinNr;
	public void setLieferscheinNr(String lieferscheinNr) {
		this.lieferscheinNr = lieferscheinNr;
On the client-side the following exception is fired during deserialization:
Caused by: com.caucho.hessian.io.HessianFieldException: de.myapp.common.we.DTOBeleg.typ: de.myapp.common.we.DTOLieferschein (DTOLieferschein [allbel_id=0, lieferscheinNr=00039023]) cannot be assigned to de.myapp.common.we.BelegTyp
	at com.caucho.hessian.io.JavaDeserializer.logDeserializeError(JavaDeserializer.java:589)
	at com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializer.deserialize(JavaDeserializer.java:387)
	at com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeserializer.java:233)
	at com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeserializer.java:157)
	at com.caucho.hessian.io.SerializerFactory.readObject(SerializerFactory.java:364)
	at com.caucho.hessian.io.Hessian2Input.readObjectInstance(Hessian2Input.java:2017)
	at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input.java:1943)
	at com.caucho.hessian.io.CollectionDeserializer.readList(CollectionDeserializer.java:78)
	at com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input.java:1666)
	at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:201)
	... 36 more
I know that there were some issues with hessian and Java5-Enums in former versions of hessian (3.0.x)
Riena 1.1.0 uses Hessian 3.1.3, right ? So Enums should be supported.
Can anybody tell me how to avoid these errors?
Thanks in advance, Jens
[Updated on: Mon, 09 November 2009 07:29] by Moderator
Riena RCP mit redView - events - [message #496268 is a reply to message #496232] Mon, 09 November 2009 09:40 Go to previous messageGo to next message
--------------080903070108060005000003
if you're interested into Riena RCP - I'll demonstrate the next weeks
how redView (Riena EMF Dynamic Views) will enhance Riena RCP applications,
esp. if you're using a model-driven workflow.
redView (http://redview.org) will finally become open source (EPL) in
nov/dec 2009.
promised !!!
first time I presented redView together with flo at EclipseCon 2009 and
I know it took much more time as expected to reach the point where we'll
make it open source.
please notice: redView was developed by flo and me: flo does it in his
spare time beside his regular job
and I'm self-employed - so there's (till now) no company behind redView.
but there are real projects using redView.
redView provides a WYSIWYG SWT editor and can be used for prototyping,
RCP applications with riena UI + LnF
or as a nice UI for WebServices. redView Views can be generated using
openArchitectureWare (MWE / Xpand / Xtend)
the next weeks we'll fill some gaps and create documentation and I'll
also demonstrate redView:
Munich, W-JAX, 2009-11-11, BOF, Room Barcelona, 19:30 - 20:30
"Was man mit Eclipse EMF alles machen kann: Business UIs modellgetrieben"
(What you can do with Eclipse EMF: Business UIs model-driven)
http://it-republik.de/jaxenter/wjax09/
Karlsruhe, Open Source EXPO, 2009-11-15 + 2009-11-16 at Exhibition
and 2009-11-16, 16:35 - 17:05 Open Stage
http://it-republik.de/konferenzen/openexpo/psecom,id,1.html
Eclipse Democamp Frankfurt, 2009-11-26
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt
Eclipse Democamp Hamburg, 2009-12-04
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg
(and Flo will present redView at Eclipse Democamp, Vienna, 2009-11-30
http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na)
read more about redView at http://redview.wordpress.com/
or http://ekkescorner.wordpress.com/
or follow me at @twitter http://twitter.com/ekkescorner
I'll publish the links soon after redView can be downloaded (EPL)
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
applications,<br>
esp. if you're using a model-driven workflow.<br>
<br>
redView (<a class="moz-txt-link-freetext" href="http://redview.org">http://redview.org</a>) will finally become open source (EPL) in
nov/dec 2009.<br>
promised !!!<br>
<br>
first time I presented redView together with flo at EclipseCon 2009 and<br>
we'll make it open source.<br>
<br>
spare time beside his regular job<br>
and I'm self-employed - so there's (till now) no company behind redView.<br>
but there are real projects using redView.<br>
<br>
RCP applications with riena UI + LnF<br>
openArchitectureWare (MWE / Xpand / Xtend)<br>
<br>
also demonstrate redView:<br>
<br>
Munich, W-JAX, 2009-11-11, BOF, Room Barcelona, 19:30 - 20:30<br>
modellgetrieben"<br>
(What you can do with Eclipse EMF: Business UIs model-driven)<br>
<a class="moz-txt-link-freetext" href="http://it-republik.de/jaxenter/wjax09/">http://it-republik.de/jaxenter/wjax09/</a><br>
<br>
Karlsruhe, Open Source EXPO, 2009-11-15 + 2009-11-16 at Exhibition<br>
and 2009-11-16, 16:35 - 17:05 Open Stage<br>
<a class="moz-txt-link-freetext" href="http://it-republik.de/konferenzen/openexpo/psecom,id,1.html">http://it-republik.de/konferenzen/openexpo/psecom,id,1.html</a><br>
<br>
Eclipse Democamp Frankfurt, 2009-11-26<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Fran kfurt</a><br>
<br>
Eclipse Democamp Hamburg, 2009-12-04<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Hamb urg</a><br>
<br>
(and Flo will present redView at Eclipse Democamp, Vienna, 2009-11-30<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na"> http://wiki.eclipse.org/Eclipse_DemoCamps_November_2009/Vien na</a>)<br>
<br>
read more about redView at <a class="moz-txt-link-freetext" href="http://redview.wordpress.com/">http://redview.wordpress.com/</a><br>
or <a class="moz-txt-link-freetext" href="http://ekkescorner.wordpress.com/">http://ekkescorner.wordpress.com/</a><br>
or follow me at @twitter <a class="moz-txt-link-freetext" href="http://twitter.com/ekkescorner">http://twitter.com/ekkescorner</a><br>
<br>
I'll publish the links soon after redView can be downloaded (EPL)<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------080903070108060005000003--
Re: Java 5 Enums / Hessian / Riena [message #496477 is a reply to message #496232] Tue, 10 November 2009 03:57 Go to previous messageGo to next message
Hi Jens,
I tried to reproduce your problem. But I could not reproduce it.
Within our test bundle we have a AbstractSerializerFactoryTestCase
class. With that I wrote a test case (see below) trying to reproduce
your problem. I added equals/hashCode for comparing the expected and
result objects. Could you please run the test in your environment?
(Yes, we use Hessian 3.1.3)
public class EnumProblemOnNG extends AbstractSerializerFactoryTestCase {
public void testEnumGiven() {
DTOLieferschein lieferschein = new DTOLieferschein();
lieferschein.setLieferscheinNr("0815");
lieferschein.setTyp(BelegTyp.Lieferschein);
assertTrue(isBackAndForthOk(lieferschein,
HessianSerializerVersion.Two, null));
public void testEnumNotGiven() {
private static enum BelegTyp {
Lieferschein("LIEFERUNG"), Retoure("RETOURE"), Rechnung("REKO");
private final static Map<String, BelegTyp> map = new HashMap<String,
BelegTyp>();
private BelegTyp(String val) {
this.value = val;
return value;
return value;
// ... this is the DTO which owns the Enum:
private static class DTOBeleg {
public int hashCode() {
final int prime = 31;
int result = 1;
result = prime * result + ((typ == null) ? 0 : typ.hashCode());
return result;
public boolean equals(Object obj) {
if (this == obj) {
return true;
if (obj == null) {
return false;
if (getClass() != obj.getClass()) {
return false;
DTOBeleg other = (DTOBeleg) obj;
if (typ == null) {
if (other.typ != null) {
return false;
} else if (!typ.equals(other.typ)) {
return false;
return true;
return typ;
this.typ = typ;
//... and this is the DTO which has to be transferred:
public static class DTOLieferschein extends DTOBeleg {
int result = super.hashCode();
result = prime * result + ((lieferscheinNr == null) ? 0 :
lieferscheinNr.hashCode());
return result;
if (this == obj) {
return true;
if (!super.equals(obj)) {
return false;
return false;
DTOLieferschein other = (DTOLieferschein) obj;
if (lieferscheinNr == null) {
if (other.lieferscheinNr != null) {
return false;
} else if (!lieferscheinNr.equals(other.lieferscheinNr)) {
return false;
return true;
return "DTOLieferschein [lieferscheinNr=" + lieferscheinNr + ", typ="
+ typ + "]";
jens.mayer1@gmx.de wrote:
> This is the Enum:
> Retoure("RETOURE"),
> Rechnung("REKO");
> this.value = val;
> return value;
> @Override
> return value;
> return typ;
> this.typ = typ;
> at
> com.caucho.hessian.io.JavaDeserializer.logDeserializeError(J avaDeserializer.java:589)
> at
> com.caucho.hessian.io.JavaDeserializer$ObjectFieldDeserializ er.deserialize(JavaDeserializer.java:387)
> at
> com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeseri alizer.java:233)
> at
> com.caucho.hessian.io.JavaDeserializer.readObject(JavaDeseri alizer.java:157)
> at
> com.caucho.hessian.io.SerializerFactory.readObject(Serialize rFactory.java:364)
> at
> com.caucho.hessian.io.Hessian2Input.readObjectInstance(Hessi an2Input.java:2017)
> at
> com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1943)
> at
> com.caucho.hessian.io.CollectionDeserializer.readList(Collec tionDeserializer.java:78)
> at
> com.caucho.hessian.io.Hessian2Input.readObject(Hessian2Input .java:1666)
> at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.j ava:201)
> ... 36 more
Re: Java 5 Enums / Hessian / Riena [message #498320 is a reply to message #496477] Mon, 16 November 2009 08:41 Go to previous messageGo to next message
Hi Stefan,
sorry for answering that late (last week I attended the w-jax 2009 in München - great conference!).
hmm - maybe I'm too dumb but I can't find the AbstractSerializerFactoryTestCase in the test bundle (nor Java Search neither Text Search gave any results). I'm using Riena 1.1.0 - maybe it's implemented only in 1.2.0.Mx ?
May you tell me the package that should contain that Testcase?
Jens
Re: Java 5 Enums / Hessian / Riena [message #498344 is a reply to message #498320] Mon, 16 November 2009 09:23 Go to previous message
Hi Jens,
Yes, it was introduced in 1.2.0.M1.
You could just fetch the head version of the package
"org.eclipse.riena.internal.communication.hessian" from our test bundle.
That should be sufficient for running the test.
Tschüß,
Stefan
> Hi Stefan,
> Jens
Riena RCP mit redView - events - [message #584071 is a reply to message #496232] Mon, 09 November 2009 09:40 Go to previous message
nov/dec 2009.
promised !!!
skype: ekkes-corner
<html>
<head>
</head>
applications,<br>
<br>
nov/dec 2009.<br>
promised !!!<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
Re: Java 5 Enums / Hessian / Riena [message #584078 is a reply to message #496232] Tue, 10 November 2009 03:57 Go to previous message
Hi Jens,
BelegTyp>();
this.value = val;
return value;
return value;
int result = 1;
return result;
if (this == obj) {
return true;
if (obj == null) {
return false;
return false;
if (typ == null) {
return false;
return false;
return true;
return typ;
this.typ = typ;
return result;
if (this == obj) {
return true;
return false;
return false;
return false;
return false;
return true;
+ typ + "]";
> This is the Enum:
> Retoure("RETOURE"),
> Rechnung("REKO");
> this.value = val;
> return value;
> @Override
> return value;
> return typ;
> this.typ = typ;
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
Re: Java 5 Enums / Hessian / Riena [message #584102 is a reply to message #496477] Mon, 16 November 2009 08:41 Go to previous message
Hi Stefan,
Jens
Re: Java 5 Enums / Hessian / Riena [message #584112 is a reply to message #584102] Mon, 16 November 2009 09:23 Go to previous message
Hi Jens,
Tschüß,
Stefan
> Hi Stefan,
> Jens
Previous Topic:Using SSLConfiguration
Next Topic:Riena 1.2.0.M3 is available
Current Time: Sat Jul 26 17:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.03858 seconds
