Home » Archived » MOFScript » MOFScript and UML State machines
MOFScript and UML State machines [message #494798] Mon, 02 November 2009 11:52 Go to next message
I am using MOFScript to parse an UML model of a State Machine. I have been able to do it without major complications but for some reason I cannot access the "Trigger"s in the state transitions.
I can access other (I do not how to call them) elements in the transition such as "effect" and "guard". To get the Trigger I have tried many transformations without any success.
I am not sure if this is important but if in a transition I do a:
self.ownedElement.size()
I get only 2 (guard, effect) elements instead of 3 (guard, effect and trigger).
I am not UML savy, so probably I am doing a very silly mistake. Any ideas?
thanks,
Arturo S.
Re: MOFScript and UML State machines [message #495576 is a reply to message #494798] Thu, 05 November 2009 06:53 Go to previous messageGo to next message
Hello Arturo,
Does the following transformation?
uml.Transition::test(){
self.trigger->forEach(trigg:uml.Trigger){
trigg.triggerTest()
uml.Trigger::triggerTest(){
self.name
G
Re: MOFScript and UML State machines [message #495930 is a reply to message #495576] Fri, 06 November 2009 11:52 Go to previous messageGo to next message
Yes, it worked. It seems that I was doing something wrong when generating the diagram to UML2 (well, I think that was the reason) or in the previous version of my code.
Initially I tried the code you sent and it did not work. Then I did some changes in my translation script and in the diagram and it worked.
Thanks!
-as
Re: MOFScript and UML State machines [message #495931 is a reply to message #495576] Fri, 06 November 2009 11:54 Go to previous messageGo to next message
Thanks!
-as
Re: MOFScript and UML State machines [message #580161 is a reply to message #495576] Fri, 06 November 2009 11:54 Go to previous messageGo to next message
Thanks!
-as
Re: MOFScript and UML State machines [message #580180 is a reply to message #495576] Fri, 06 November 2009 11:54 Go to previous message
Thanks!
-as
Previous Topic:MOFScript and UML State machines
Next Topic:Find the Target for a message
Current Time: Thu Jul 24 20:33:02 EDT 2025
Powered by FUDForum. Page generated in 0.03551 seconds
