| Create 'template' xml from xsd model [message #49177] |
Tue, 20 July 2004 12:59   |
Eclipse User  |
Originally posted by: gary_.pureedge.com
Given an XSDSchema object I want to to generate a template XML tree using
all elements defined in the schema.  In other words it would be the most
complete document that could be generated from the schema with all optional
elements and choices.
In my case I intend to generate an XML model that also contains not one but
all of the <choice> elements which means of course that the xml will not
validate against the schema but that's not what I want to do with it.  I
just want an XML model that contains all the elements defined in the schema.
If someone could point me to the right place or has any ideas I would
appreciate it very much.  Has anyone seen anything like this before or
anything close?  Maybe anything that generates sample XML from a schema
would help.
| Re: Create 'template' xml from xsd model [message #49586 is a reply to message #49526] |
Tue, 27 July 2004 14:38   |
Eclipse User  |
Great.  Could be exactly what I'm looking for and I may be interested in
contributing as well on this one.  I'll let Rob Tice know.
Gary
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ce5uit$54m$1@eclipse.org...
Gary,
The note from Tod Rice on 04/28 will be useful.
Gary wrote:
If you have any references I would appreciate it.  Even if you remember a
subject line so I can search myself
news:ce2rgi$n3h$1@eclipse.org...
optional
but
schema.
would help.
Gary,
There have been previous appends on this subject in the newsgroup,
including folks willing to share code that does this kind of thing.  If
I have time later, I'll track the notes down...
| Re: Create 'template' xml from xsd model [message #589844 is a reply to message #49177] |
Mon, 26 July 2004 07:57   |
Eclipse User  |
>would help.
Gary,
| Re: Create 'template' xml from xsd model [message #589888 is a reply to message #49377] |
Mon, 26 July 2004 16:55   |
Eclipse User  |
optional
but
schema.
> >would help.
> Gary,
| Re: Create 'template' xml from xsd model [message #589913 is a reply to message #49466] |
Tue, 27 July 2004 12:08   |
Eclipse User  |
--------------020108080004030103070404
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Gary wrote:
>Thanks
>optional
>but
>schema.
>>>would help.
>>Gary,
Content-Type: text/html; charset=us-ascii
<html>
<head>
  <title></title>
</head>
Gary,<br>
<br>
The note from Tod Rice on 04/28 will be useful.<br>
<br>
<br>
Gary wrote:<br>
<blockquote cite="midce3r0j$6hs$1@eclipse.org" type="cite">
  <pre wrap="">Thanks
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ce2rgi$n3h$1@eclipse.org">news:ce2rgi$n3h$1@eclipse.org</a>...
  </pre>
  <blockquote type="cite">
    <pre wrap="">Gary wrote:
    </pre>
      <pre wrap="">Given an XSDSchema object I want to to generate a template XML tree using
      </pre>
    </blockquote>
  </blockquote>
  <pre wrap=""><!---->optional
  </pre>
      <pre wrap="">elements and choices.
      </pre>
    </blockquote>
  </blockquote>
  <pre wrap=""><!---->but
  </pre>
      <pre wrap="">all of the <choice> elements which means of course that the xml will not
      </pre>
    </blockquote>
  </blockquote>
  <pre wrap=""><!---->schema.
  </pre>
      <pre wrap="">If someone could point me to the right place or has any ideas I would
would help.
      </pre>
    </blockquote>
    <pre wrap="">Gary,
    </pre>
  </blockquote>
  </pre>
</blockquote>
<br>
</body>
</html>
--------------020108080004030103070404--
| Re: Create 'template' xml from xsd model [message #589933 is a reply to message #49526] |
Eclipse User  |
Gary
Gary,
optional
but
schema.
would help.
Gary,
FUDForum. Page generated in 0.04866 seconds
