Home » Eclipse Projects » Remote Application Platform (RAP) » Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 (Trying to run HelloWorld)
Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #495676] Thu, 05 November 2009 13:00 Go to next message
I am getting the following error when trying to run the RAP HelloWorld.
http://127.0.0.1:3475/rap?startup=hello
HTTP ERROR 404
ProxyServlet: /rap
Powered by Jetty://
I have tried all variations. Manual and Automatic installs. I have even run it on a fresh Windows and Solaris OS install.
Is anyone else having this problem?
Thanks for any help.
Richard Catlin
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #495683 is a reply to message #495676] Thu, 05 November 2009 13:17 Go to previous messageGo to next message
Additionally, I have tried both 1.2 and 1.3 releases.
Here is the console exceptions:
osgi> !SESSION 2009-11-05 09:51:41.828 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
Command-line arguments: -dev file:D:/eclipse_workspace/eclipse-sizing-rap/.metadata/.plug ins/org.eclipse.pde.core/Rap1/dev.properties -os win32 -ws win32 -arch x86 -console -consolelog
!ENTRY org.eclipse.rap.ui.workbench 4 0 2009-11-05 09:51:42.875
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.help; bundle-version=" was not resolved.
!SUBENTRY 2 org.eclipse.rap.ui.workbench 2 0 2009-11-05 09:51:43.078
!MESSAGE Missing required bundle org.eclipse.help_[3.2.0,4.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-11-05 09:51:43.078
!MESSAGE Bundle Rap1_1.0.0.qualifier was not resolved.
!SUBENTRY 2 Rap1 2 0 2009-11-05 09:51:43.078
!MESSAGE Missing required bundle org.eclipse.rap.ui_0.0.0.
!MESSAGE Bundle org.eclipse.rap.demo_1.3.0.20090929-1121 was not resolved.
!SUBENTRY 2 org.eclipse.rap.demo 2 0 2009-11-05 09:51:43.078
!MESSAGE Missing required bundle org.eclipse.rap.ui.views_0.0.0.
!MESSAGE Bundle org.eclipse.rap.ui_1.3.0.20090929-1121 was not resolved.
!SUBENTRY 2 org.eclipse.rap.ui 2 0 2009-11-05 09:51:43.078
!MESSAGE Missing required bundle org.eclipse.rap.ui.workbench_[1.2.0,2.0.0).
!MESSAGE Bundle org.eclipse.rap.demo.databinding_1.3.0.20090929-1121 was not resolved.
!SUBENTRY 2 org.eclipse.rap.demo.databinding 2 0 2009-11-05 09:51:43.078
!MESSAGE Bundle org.eclipse.rap.ui.views_1.3.0.20090929-1121 [32] was not resolved.
!SUBENTRY 2 org.eclipse.rap.ui.views 2 0 2009-11-05 09:51:43.078
!MESSAGE Missing required bundle org.eclipse.rap.ui_[1.2.0,4.0.0).
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #495684 is a reply to message #495683] Thu, 05 November 2009 13:21 Go to previous messageGo to next message
ENTRY Rap1 4 0 2009-11-05 09:51:42.875
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="0.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:554)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:461)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:246)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:442)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
!ENTRY org.eclipse.rap.demo 4 0 2009-11-05 09:51:42.875
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui 4 0 2009-11-05 09:51:42.890
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench; bundle-version="[1.2.0,2.0.0)"
!ENTRY org.eclipse.rap.demo.databinding 4 0 2009-11-05 09:51:42.890
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui.views 4 0 2009-11-05 09:51:42.890
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="[1.2.0,4.0.0)"
2009-11-05 09:51:42.921:org.mortbay.log:INFO: Logging to STDERRorg.mortbay.log via org.mortbay.log.Slf4jLog
2009-11-05 09:51:42.968::INFO: jetty-6.1.x
2009-11-05 09:51:43.031::INFO: Started SelectChannelConnector@0.0.0.0:3475
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #495714 is a reply to message #495676] Thu, 05 November 2009 15:01 Go to previous messageGo to next message
> HTTP ERROR 404
> Powered by Jetty://
Have you looked at the Getting Started guide?
http://www.eclipse.org/rap/gettingstarted.php
It looks like your bundle that hosts the RAP application may not be
started? Are you pointing to the RAP target platform?
You can track me down on Skype if you need help.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #495890 is a reply to message #495676] Fri, 06 November 2009 09:22 Go to previous messageGo to next message
Hi Richard,
sometimes the application is not yet started when the launcher opens the
browser. In this case, reloading the page (F5 in the browser) helps. Is
this what you are seeing?
Regards, Ralf
> HTTP ERROR 404
> Powered by Jetty://
> Regards,
> Richard Catlin
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #651438 is a reply to message #495676] Sun, 30 January 2011 16:34 Go to previous messageGo to next message
Hello ,
I have the same problem now:
HTTP ERROR 404
ProxyServlet: /rap
Do you know already , what to do with it?
Michal Kuchar, Prague
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #804122 is a reply to message #495676] Wed, 22 February 2012 03:22 Go to previous messageGo to next message
Same problem here... even followed some installation instructions tried it on Windows 7, Ubuntu Linux 11.10... I just can't start the simple HelloWorld application.
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #804127 is a reply to message #495676] Wed, 22 February 2012 03:22 Go to previous messageGo to next message
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #804157 is a reply to message #804127] Wed, 22 February 2012 04:08 Go to previous messageGo to next message
if you run your application from the IDE that's open the browser
automatically, probably you run into this bug:
282756: [Tooling] Browser is opened too early
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282756
The solution is to press the refresh button on the browser.
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Problem accessing /rap. Reason: ProxyServlet: /rap HTTP ERROR 404 [message #892259 is a reply to message #495676] Wed, 27 June 2012 10:11 Go to previous message
Hi, I had the same problem and resolved it by
downloading the rap target runtime from
the eclipse site.
Because at some point my rap target version was too recent for
my eclipse version.
Hope it helps.
Previous Topic:Scrolling in a Combobox even if not focused
Next Topic:Disable Refresh-Key F5
Current Time: Wed Jul 23 16:16:52 EDT 2025
Powered by FUDForum. Page generated in 0.25931 seconds
