Home » Eclipse Projects » Eclipse Platform » Display view in Eclipse menu Window-> Show View
Display view in Eclipse menu Window-> Show View [message #495493] Thu, 05 November 2009 00:40 Go to next message
I have created an Eclipse plugin which creates a view in Eclipse. Currently it is displayed in the Eclipse menu as :
'Window->Show View->Others'.
I want to show it in 'Window -> Show View' and not under the submenu 'Others'.
I have tried it giving the 'Category' of the view in the plugin.xml file as 'org.eclipse.ui' but it is still showing the view in 'Others' submenu.
Is there any other way to do so? Any suggestions are helpful in this regard.
Thanks in advance,
Abhinav
[Updated on: Sat, 07 November 2009 13:06] by Moderator
Re: Display view in Eclipse menu Window-> Show View [message #495599 is a reply to message #495493] Thu, 05 November 2009 08:17 Go to previous messageGo to next message
> 'Others'.
> regard.
> Thanks in advance,
> Abhinav
In your Perspective class that implements IPerspectiveFactory, you have
to add a view shortcut, like this :
public void createInitialLayout(IPageLayout layout)
layout.addShowViewShortcut(your_view_ID);
Don't forget to reset your perspective (Windows / Reset Perspective ...)
to make this work.
Hope this help !
David
Re: Display view in Eclipse menu Window-> Show View [message #496142 is a reply to message #495599] Sun, 08 November 2009 23:28 Go to previous messageGo to next message
Dear David,
The piece of code you sent seems working as it brings the view shortcut into Window->Show View->Other..->General category. Earlier it was coming into Other...->Others category. But I want it to directly display under Window->Show View and not under Other..->General submenu. Do I need to change some Eclipse preferences to do so? I am not able to locate where I need to make change for that.
Also is it possible to completely hide/remove any view entry/shortcut to appear from Window->Show View menu? As I want to embed them in a separate menu.
Thanks a lot for your reply..
[Updated on: Sun, 08 November 2009 23:30] by Moderator
Re: Display view in Eclipse menu Window-> Show View [message #496157 is a reply to message #496142] Mon, 09 November 2009 03:38 Go to previous messageGo to next message
> Dear David,
> This is working as it brings the view shortcut into Window->Show
> separate menu.
Hi Abhinav,
It works great for me.
I have set the org.eclipse.ui.perspectives Entensions Point. My
perspective class implements IPerspectiveFactory. If i let the class
empty, with only createInitialLayout method does nothing, the Windows /
Show views menu contains only Others. If I add a view shortcut in this
method, Windows / Show views menu contains my view (not in Others /
General). I do not understand where your problem comes from ...
David
PS : as i said it before, you have to reset your perspective to make it
works
Re: Display view in Eclipse menu Window-> Show View [message #506041 is a reply to message #496157] Tue, 05 January 2010 15:12 Go to previous messageGo to next message
How can I show the Problems view programmatically in a plugin ? (by hand it would be via menu Window, ShowView, Problems).
So when it isn't already there it should be added ... and when it's already there the Problems tab should be selected (as if you did a mouseclick on it).
Re: Display view in Eclipse menu Window-> Show View [message #506110 is a reply to message #506041] Wed, 06 January 2010 03:34 Go to previous messageGo to next message
Hi Kitesurfer,
You can try the following:
String problemViewID = "org.eclipse.ui.views.problems";
IViewPart problemView = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView(problemViewID);
Re: Display view in Eclipse menu Window-> Show View [message #506252 is a reply to message #506110] Wed, 06 January 2010 12:11 Go to previous messageGo to next message
Abhinav Mishra wrote on Wed, 06 January 2010 03:34
Thanks ... I get an exception on the "IViewPart problemView" line. Any ideas ?
try {
problemView.setFocus();
} catch (Exception e) {
e.printStackTrace();
at article.editor.markers.MarkingErrorHandler.removeExistingMar kers(MarkingErrorHandler.java:110)
at article.editor.XMLEditor.validateAndMark(XMLEditor.java:77)
at article.editor.XMLEditor.doSetInput(XMLEditor.java:53)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Display view in Eclipse menu Window-> Show View [message #506271 is a reply to message #506041] Wed, 06 January 2010 13:00 Go to previous messageGo to next message
What you need to do is call
IWorkbenchPage#showView(org.eclipse.ui.IPageLayout.ID_PROBLE M_VIEW)
What are you doing or where are you when you want to do this? An
action? An existing view? for example, from within a view simply:
getSite().getPage().showView(IPageLayout.ID_PROBLEM_VIEW);
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Display view in Eclipse menu Window-> Show View [message #506272 is a reply to message #506252] Wed, 06 January 2010 13:05 Go to previous messageGo to next message
This constant is already defined in IPageLayout
> try {
never call part.setFocus() ... the javadoc forbids it.
Are you sure? The NPE would have come from "problemView.setFocus();"
since that ID looks invalid.
If that's not it, they you would have to break up the long line to find
out which get*() call return null.
PW
Paul Webster
Re: Display view in Eclipse menu Window-> Show View [message #506294 is a reply to message #506271] Wed, 06 January 2010 15:11 Go to previous messageGo to next message
Paul Webster wrote on Wed, 06 January 2010 13:00
In this case its done within a self-written class instanced out of "doSetInput" of:
public class XMLEditor extends TextEditor
At the end of the day I'm going to do it behind a menu-item that uploads the file to a hostsystem, compiles on the host and sets ProblemMarkers for the compile-errors/warnings (that are returned in a downloaded textfile).
It dumps on the last line of this code :
try {
IWorkbench Workbench = PlatformUI.getWorkbench();
IWorkbenchWindow WorkbenchWindow = Workbench.getActiveWorkbenchWindow();
IWorkbenchPage WorkbenchPage = WorkbenchWindow.getActivePage();
WorkbenchPage.showView(IPageLayout.ID_PROBLEM_VIEW);
Re: Display view in Eclipse menu Window-> Show View [message #506704 is a reply to message #506294] Fri, 08 January 2010 16:04 Go to previous messageGo to next message
> "doSetInput" of:
If you are in the text editor, use getSite().getPage() to get your page.
Try that for now to confirm you can open the correct view.
PW
Paul Webster
Re: Display view in Eclipse menu Window-> Show View [message #896678 is a reply to message #506704] Thu, 19 July 2012 07:08 Go to previous messageGo to next message
Hi Paul,
I get the same exception when I use PlatformUI. The exception is thrown at
since I am using it a non ui thread.
Is there a way to open the Problems view without using PlatformUI? I want to open the problems view in a non ui thread also
Latha
Re: Display view in Eclipse menu Window-> Show View [message #896719 is a reply to message #896678] Thu, 19 July 2012 09:40 Go to previous messageGo to next message
If all your only problem is that you are not on a UI thread use this code:
// If you are only the UI thread get the currently associated display
Display display = Display.getCurrent();
if (display == null)
    // Otherwise get the display associated with the UI thread
    display = Display.getDefault();
display.asyncExec(new Runnable() {
    public void run() {
        // Insert your code here:
        // getSite().getPAge() ...
Re: Display view in Eclipse menu Window-> Show View [message #896721 is a reply to message #896719] Thu, 19 July 2012 09:48 Go to previous message
use
display.syncExec(...
if you want synchronous behavior.
Previous Topic:Eclipse configurations
Next Topic:Linux text annotations (Juno)
Current Time: Sat Jul 26 21:02:35 EDT 2025
Powered by FUDForum. Page generated in 0.06446 seconds
