Home » Modeling » EMF » child creation extenders(multiple and nested)
child creation extenders [message #495173] Tue, 03 November 2009 20:04 Go to next message
I have a model which uses child creation extenders, and I was having some problems with it, so I reduced it down to the simplest form that I could, and I am still having the issue.
I have three separate model plug-in projects: test1, test2, and test3. I have left out all path info for brevity:
test1.ecore:
EPackage test1
..EClass Container
....EReference items : Item (containment=true, bounds=0..*)
..EClass Item (abstract=true, interface=true)
test2.ecore:
EPackage test2
..EClass ContainerItem -> Item
Loaded resource test1.ecore
test3.ecore:
EPackage test3
..EClass OtherItem -> Item
test1.genmodel:
..Child Creation Extenders=false
..Extensible Provider Factory=true
test2.genmodel:
..Child Creation Extenders=true
Referenced genmodel test1.genmodel
test3.genmodel:
I then generate model, edit, and editor for test1, and model and edit for test2 and test3.
When I run the code, I create a new model file in the editor, and am able to add either ContainerItem or OtherItem in the top level container.
However, if I try to add a child to ContainerItem, the only type of item I can add is ContainerItem. It doesn't see the OtherItem definition.
Am I missing something in my configuration?
I can provide the project files if anyone is interested.
[Updated on: Tue, 03 November 2009 20:35] by Moderator
Re: child creation extenders [message #495176 is a reply to message #495173] Tue, 03 November 2009 20:35 Go to previous messageGo to next message
After looking at the generated code, it can be probably be made simpler.
test1 defines EClass Item (virtual, abstract)
test2 defines EClass Container which contains EReference items : Item
test3 defines EClass OtherItem -> Item
I've not tested this layout yet, but I believe it would produce similar results when editing a Container.
Re: child creation extenders [message #495351 is a reply to message #495173] Wed, 04 November 2009 10:39 Go to previous messageGo to next message
--------------090701090507020107030709
Ray,
Does it sound like this?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274884
Try the workaround mentioned in that bug.
> test1.ecore:
> EPackage test1
> .EClass Container
> test2.ecore:
> EPackage test2
> test3.ecore:
> EPackage test3
> test1.genmodel:
> test2.genmodel:
> test3.genmodel:
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Ray,<br>
<br>
Does it sound like this?<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=274884">https://bugs.eclipse.org/bugs/show_bug.cgi?id=274884</a><br>
</blockquote>
Try the workaround mentioned in that bug.<br>
<br>
<br>
Ray Kelm wrote:
<blockquote cite="mid:hcqjuv$ol4$1@build.eclipse.org" type="cite">I
<br>
<br>
<br>
<br>
test1.ecore:
<br>
<br>
EPackage test1
<br>
..EClass Container
<br>
<br>
<br>
<br>
test2.ecore:
<br>
<br>
EPackage test2
<br>
..EClass ContainerItem -&gt; Item
<br>
<br>
<br>
<br>
test3.ecore:
<br>
<br>
EPackage test3
<br>
..EClass OtherItem -&gt; Item
<br>
<br>
<br>
test1.genmodel:
<br>
<br>
<br>
<br>
<br>
test2.genmodel:
<br>
<br>
<br>
<br>
<br>
<br>
test3.genmodel:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
container.
<br>
<br>
definition.
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------090701090507020107030709--
Re: child creation extenders [message #495465 is a reply to message #495351] Wed, 04 November 2009 19:18 Go to previous messageGo to next message
Ed Merks wrote on Wed, 04 November 2009 10:39
No, it's a bit different than that. In my case, the "root" package defines an interface which is implemented by a class in one child, and is referenced by a class in the other child. The second child does not see the availability of the class defined in the first child.
Both child packages have a usedGenPackages reference back to the root package, so unfortunately, the workaround mentioned in that bug is not relevant.
Re: child creation extenders [message #495478 is a reply to message #495351] Wed, 04 November 2009 20:56 Go to previous messageGo to next message
I traced through the code a bit, and I think I know what is happening.
test1.ecore:
EClass Item (interface, abstract)
EClass Container
EReference items (0..*) to Item
test2.ecore:
test3.ecore:
The code responsible for returning the correct list of potential new children is In Test2ItemProviderAdapterFactory.getNewChildDescriptors().
When "Extensible Provider Factory" is true, the generated code tries to get extensions, but those that are registered against the test2 namespace.
When "Extensible Provider Factory" is false, it does not go look for extended items, merely calling ContainerItemItemProvider.collectNewChildDescriptors(), which only returns a single new child descriptor for creating a ContainerItem.
There is no place where it looks for other implementations of Item that could possibly be added as a child of ContainerItem.
I think the problem is that it dispatches on the type of the container object, rather than the type of the contained object.
So in ContainerItemItemProvider.collectNewChildDescriptors() it would need to look for extensions to the Item class, using the namespace of the EPackage that is associated with Item, rather than assuming that Item is part of the current EPackage.
So it's a bug, I think.
Re: child creation extenders [message #495561 is a reply to message #495478] Thu, 05 November 2009 06:08 Go to previous message
Ray,
As I mentioned in the bugzilla, I don't have time to manufacture test
cases from verbal instructions so please attach a representative example
and then I'll look at that.
> test1.ecore:
> EClass Container
> test2.ecore:
> test3.ecore:
> namespace.
Previous Topic:How to figure out all attributes and associations of any model class
Next Topic:Extending a model
Current Time: Fri Jul 18 07:31:09 EDT 2025
Powered by FUDForum. Page generated in 0.06986 seconds
