[headless junit] pde junit support [message #495257] |
Wed, 04 November 2009 06:59  |
Hi there,
when trying to execute my launch configuration using headless buckminster junit command, I get the following message:
junit '-l' '/my.plugin.folder/AllTests.launch'
Doing full workspace refresh
Waiting for jobs to end
Required plug-in 'org.eclipse.pde.junit.runtime' could not be found.
Does that mean JUnit Plugin Tests are not supported?
If so, are there already any tangible plans for that?
Joerg
[headless junit] pde junit support [UPDATE] [message #498556 is a reply to message #496817] |
Tue, 17 November 2009 08:42   |
Hi there.
Reinstalling buckminster headless 3.6 gives me version r10881 - but unfortunately, the junit command error (see below) remains also with this update.
Regards.
Joerg
Joerg Buchberger wrote on Wed, 11 November 2009 08:37 | Hi all.
Since we are under a little time pressure, we now also tried to make use of a new project hosted at google. It's called headlesseclipse: http://code.google.com/p/headlesseclipse/
With the support of the project owners, we currently try to extend that plugin to support JUnit Plugin Test run configurations to get launched. We are now at a point, we didn't reach yet with neither buckminster nor automated test framework. Our plugin test suites actually run headlessly!
Nevertheless, I'm eager to give headless buckminster another try as soon as Achim confirms his assumption+fix:
Achim Demelt wrote on Sun, 08 November 2009 11:14 | Hi Joerg,
Launching JUnit plug-in tests is fully supported. That said, the PDE team
may have introduced this new org.eclipse.pde.junit.runtime bundle that I
haven't seen before. I'll look into this. Maybe all we need to do is include
this bundle in our Buckminster headless feature and PDE JUnit launching will
work again.
Joerg Buchberger wrote on Wed, 04 November 2009 06:59 | when trying to execute my launch configuration using headless buckminster junit command, I get the following message:
Waiting for jobs to end Required plug-in 'org.eclipse.pde.junit.runtime' could not be found.
Re: [headless junit] pde junit support [SOLVED] [message #500042 is a reply to message #499543] |
Tue, 24 November 2009 13:58  |
Jorg,
Great, thanks for your patience!
Achim
Joerg Buchberger wrote:
> Joerg Buchberger wrote on Sun, 22 November 2009 16:44
>> Achim Demelt wrote on Thu, 19 November 2009 02:41
>> > I added the missing bundle to the pde.headless feature. A new build is
>> > now available. Could you please give it another try and see if there
>> > are any more problems? If so, please file a bug so that we can track
>> > this problem better.
>> Thank you, Achim.
>> I'll update and retry tomorrow.
>> Cheers.
>> Joerg
> Thanks, Achim - plugin tests now are running!
> INFO: Tests finished.
> INFO: Total number of tests executed: 1365
> INFO: Successful tests: 1225
> INFO: Failed tests: 31
> INFO: Errors: 109
> INFO: Ignored tests: 0
> INFO: Overall status: Error
> Cheers,
> Joerg
FUDForum. Page generated in 0.09401 seconds
