Home » Modeling » UML2 » UML2 genmodel properties for EClasses
UML2 genmodel properties for EClasses [message #495200] Wed, 04 November 2009 02:21 Go to next message
Hi all,
i'm using the UML2 genmodel to enhance EMF with UML2-specific
capabilities. I've found 2 properties, i really can't explain to myself,
namely 'Key' and 'Pluralization Exception'. What are the purposes for
these fields?
Thanks a lot
Timothy
Re: UML2 genmodel properties for EClasses [message #495647 is a reply to message #495200] Thu, 05 November 2009 10:40 Go to previous messageGo to next message
For a property foo with upper bound > 1, the default accessor method
will be:
EList getFoos()
But if you set pluralizationException to be true, the generated accessor
will be EList getFoo().
The key thing I don't know what is for.
HTH,
Rafael
http://abstratt.com/blog/
Timothy Marc wrote:
> Hi all,
> these fields?
> Thanks a lot
> Timothy
Re: UML2 genmodel properties for EClasses [message #496373 is a reply to message #495647] Mon, 09 November 2009 14:36 Go to previous messageGo to next message
The 'Key' attribute affects the createXXX() methods.
For example, in a TemplateableElement, we set TemplateSignature as a "key"
property. If you have a look at
TemplateableElement.createTemplateBinding() it takes as a parameter a
TemplateSignature.
All features that are required to uniquely create elements should be marked
as "key" features.
- James.
"Rafael Chaves" <rafael@abstratt.com> wrote in message
news:hcurli$39s$1@build.eclipse.org...
> For a property foo with upper bound > 1, the default accessor method will
> be:
> EList getFoos()
> HTH,
> Rafael
> Timothy Marc wrote:
>> Hi all,
>> these fields?
>> Thanks a lot
>> Timothy
Re: UML2 genmodel properties for EClasses [message #504287 is a reply to message #495647] Thu, 17 December 2009 23:46 Go to previous message
The key property also affects the generated "look-up" methods.
Kenn
Re: UML2 genmodel properties for EClasses [message #628029 is a reply to message #495200] Thu, 05 November 2009 10:40 Go to previous message
will be:
EList getFoos()
HTH,
Rafael
Timothy Marc wrote:
> Hi all,
> these fields?
> Thanks a lot
> Timothy
Re: UML2 genmodel properties for EClasses [message #628036 is a reply to message #495647] Mon, 09 November 2009 14:36 Go to previous message
TemplateSignature.
as "key" features.
- James.
> be:
> EList getFoos()
> HTH,
> Rafael
> Timothy Marc wrote:
>> Hi all,
>> these fields?
>> Thanks a lot
>> Timothy
Re: UML2 genmodel properties for EClasses [message #628140 is a reply to message #495647] Thu, 17 December 2009 23:46 Go to previous message
Kenn
Previous Topic:How to change label providers in UMLEditor?
Next Topic:UML2AdapterFactoryEditingDomain question
Current Time: Tue Jul 22 22:12:26 EDT 2025
Powered by FUDForum. Page generated in 0.29349 seconds
