Home » Modeling » Modeling (top-level project) » I have a class. How do I get it's structural features?
I have a class. How do I get it's structural features? [message #495088] Tue, 03 November 2009 12:51 Go to next message
Hello --
I'm using reflection to do all sorts of cool automated things which I am HOPING I can contribute back to the open source world. However, I have one bit of ugliness:
I have a class. Not an EClass, just a plain class. I need to get its EStructuralFeatures. How do I do that? How can I look up a factory if I just have a class? Is there a way for me to get an EClass from a class? Mind you, I don't have an instance of the class, I just have the class itself.
thanks much
Tamar
Re: I have a class. How do I get it's structural features? [message #495095 is a reply to message #495088] Tue, 03 November 2009 13:12 Go to previous messageGo to next message
Hi Tamar,
Comments below...
Tamar Cohen schrieb:
> Hello --
I'm curious, what are you doing?
Why don't you use EMF reflection?
What factory do you mean?
I assume that you could determine the EClass of a java.lang.Class if you
have the GenModel of that EClass at hand. You'd have to traverse all
GenModels.
Cheers
/Eike
Re: I have a class. How do I get it's structural features? [message #495100 is a reply to message #495095] Tue, 03 November 2009 13:29 Go to previous messageGo to next message
Hi Eike -- thanks for answering --
this is what I'm doing: Since 3.6 is not out and I couldn't get Tom's UFacekit to work I've made a simple widget generation framework. It uses introspection to generate widgets either for generic Java classes or for EMF EObjects, and you can customize the layout via Java Annotations or with code / extension points (customization includes validation and conversion and grouping and layout and read/only and and and)...
So my particular EObject instances have public constructors and it all works simply. I know that this is not always how the EMF code is generated, however, and I want to support the case where I have to look up EStructuralFeatures.
As some of these widgets will be created from classes that the developer did not write, I cannot rely on having the genmodel. How might I use EMF reflection? How can I get an EClass from a class? right now the class just implements EObject.
hopefully I will be permitted to publish my work, it's really nice for the low hanging fruit / simple UI generation.
Tamar
Re: I have a class. How do I get it's structural features? [message #495116 is a reply to message #495100] Tue, 03 November 2009 15:05 Go to previous messageGo to next message
Tamar,
You generally can't get an EClass given only a java.lang.Class. If you
assume there a public constructors---EMF has an option for generating
that--then you might create an instance, cast it to EObject, and ask for
the eClass(). Alternatively, if you know the collection of possible
packages that might define the corresponding EClass, you might walk all
those package's classifiers and check if the getInstanceClass() matches.
Tamar Cohen wrote:
> Hi Eike -- thanks for answering -- this is what I'm doing: Since 3.6
> Tamar
Re: I have a class. How do I get it's structural features? [message #495120 is a reply to message #495116] Tue, 03 November 2009 15:14 Go to previous messageGo to next message
Hi Ed --
yes, thanks, that's exactly what I was doing (instantiating a temporary EObject and looking up what I want from that), and what I want to handle is the case where there is no public constructor. Hmm, looks like I may have to add support for looking up by EClass.
thank you!
Tamar
Re: I have a class. How do I get it's structural features? [message #495512 is a reply to message #495100] Thu, 05 November 2009 02:48 Go to previous message
Hi Tamar,
I would not invest into own frameworks just because an upcoming
technology at Eclipse (or elsewhere) is not yet GA. Better collaborate
with the providing team to ensure that it goes into a direction that
suits your need and help stabilizing.
Cheers
/Eike
> Tamar
Re: I have a class. How do I get it's structural features? [message #618272 is a reply to message #495095] Tue, 03 November 2009 13:29 Go to previous message
Tamar
Re: I have a class. How do I get it's structural features? [message #618273 is a reply to message #618272] Tue, 03 November 2009 15:05 Go to previous message
Tamar,
> Tamar
Re: I have a class. How do I get it's structural features? [message #618274 is a reply to message #495116] Tue, 03 November 2009 15:14 Go to previous message
Hi Ed --
thank you!
Tamar
Re: I have a class. How do I get it's structural features? [message #618275 is a reply to message #618272] Thu, 05 November 2009 02:48 Go to previous message
Hi Tamar,
Cheers
/Eike
> Tamar
Previous Topic:I have a class. How do I get it's structural features?
Next Topic:MAPPING
Current Time: Tue Jul 22 22:16:35 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
