Home » Eclipse Projects » GEF » Dynamically add/remove PaletteEntries
Dynamically add/remove PaletteEntries [message #494769] Mon, 02 November 2009 10:26 Go to next message
Hi all,
I need dynamically add/remove PaletteContainer items to PaletteRoot or make them visible/invisible.
setVisibble() method as well as add()/remove() don't show any changes.
How can I refresh changed PaletteRoot structure or any other workaround?
Can I close and open again entire palette?
Slava
Re: Dynamically add/remove PaletteEntries [message #495056 is a reply to message #494769] Tue, 03 November 2009 11:24 Go to previous message
The palette is a standard GEF based "editor", too, using the GEF MVC
design pattern. That is, PaletteEntry is the base class for the palette
model. Usually, simply modifying the model (i.e. some PaletteEntry
derived class) should work, the change is then propagated via the
EditParts (which are registered as listeners to the model) to the view.
Cheers
Jens
On 2009-11-02 16:26:01 +0100, <slavaraitsin@yahoo.com> said:
> Hi all,
> workaround? Can I close and open again entire palette?
> Slava
Previous Topic:Is it possible to mix code and graphical widgets in GEF?
Next Topic:[Draw2D]Howto comsume mouse event inside a Figure on top of a Canvas
Current Time: Sat Jul 26 18:55:41 EDT 2025
Powered by FUDForum. Page generated in 0.24294 seconds
