Home » Modeling » M2T (model-to-text transformation) » Xpand is very slow in IDE mode(Xpand is very slow in IDE mode)
Xpand is very slow in IDE mode [message #495012] Tue, 03 November 2009 09:27 Go to next message
I am using Xpand to generate the code for my project.
I am executing Xpand template on click of action in runtime environment of the IDE, this is taking lot of time.
I have written a junit test case to do the same, i am running the junit test case as junit test from the eclipse development environment.
For generating 1000 files these are the statistics:
1. In IDE mode -----120 seconds.
2. In standalone mode as a junit test ----2 seconds.
I am using exactly same code for both the above mentioned cases...
Could you please help me regarding this....
Zakir
Re: Xpand is very slow in IDE mode [message #495156 is a reply to message #495012] Tue, 03 November 2009 17:29 Go to previous message
Hi Zakir,
please see here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278753
Note that the code snippets in the comments of the tickets may be
outdated in same cases, but you'll get the idea.
Sebastian
zakir Hussain schrieb:
> Hello,
> Regards,
> Zakir
Previous Topic:Missing GenClass while using genmodel in JET Transformation Project
Next Topic:[Xpand] Problem with creating model elements from Java
Current Time: Sat Nov 08 22:54:11 EST 2025
Powered by FUDForum. Page generated in 0.02695 seconds
