Home » Archived » Memory Analyzer (MAT) » Heap Dump from Solaris gcore jdk 1.4.2.11(Heap Dump from Solaris gcore jdk 1.4.2.11)
Heap Dump from Solaris gcore jdk 1.4.2.11 [message #490804] Sat, 10 October 2009 20:14 Go to next message
Is it possible to convert a solaris core dump of a Weblogic 8.1 managed server process running with JDK 1.4.2-11 into a heap map that can be read by MAT? This jdk does not support the -XX:+HeapDumpOnOutOfMemory option and attaching jmap to the running pid takes too long. Quicker to use gcore to create a core dump file and then run some tool against that to convert to a heap dump.
Grateful for any suggestions on how to proceed.
Thanks in advance.
Bill
[Updated on: Sat, 10 October 2009 20:22] by Moderator
Re: Heap Dump from Solaris gcore jdk 1.4.2.11 [message #494935 is a reply to message #490804] Tue, 03 November 2009 05:25 Go to previous message
I just googled a little bit. There seems to be some way to use jmap on a core file. May be this would be the answer for you. However, I never tried it myself...
Should be something like
jmap -heap:format=b java corefile
here a description (but for java 6)
http://java.sun.com/javase/6/webnotes/trouble/other/matrix6- Unix.html
Looking at some bugs, this should be also available in 1.4.something
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6494472
Hope this helps.
Krum
Previous Topic:File monitoring tool
Next Topic:using "dominatorof" in query
Current Time: Wed Jul 23 10:21:07 EDT 2025
Powered by FUDForum. Page generated in 0.06171 seconds
