Home » Eclipse Projects » Rich Client Platform (RCP) » Initializing preferences when creating a new workspace
Initializing preferences when creating a new workspace [message #494459] Fri, 30 October 2009 13:32 Go to next message
I'm developping an rcp application and I want to initialize some preferences (stored in
..metadata\.plugins\org.eclipse.core.runtime\.settings) when a new workspace is created.
1- Where should I modify my application to acheive this kind of behaviour?
2- It is possible to detect that a new workspace is created in my rcp application?
3- It is possible to reuse the import preferences action of the IDE?
Vincent
Re: Initializing preferences when creating a new workspace [message #494686 is a reply to message #494459] Mon, 02 November 2009 03:13 Go to previous messageGo to next message
Hi Vincent,
have a look at the class AbstractPreferenceInitializer and the extension Point org.eclipse.core.runtime.preferences (new -> initializer), there you can set default values to your preferences.
Hopes this helps you.
Greetz,
Thomas
[Updated on: Mon, 02 November 2009 03:14] by Moderator
Re: Initializing preferences when creating a new workspace [message #494711 is a reply to message #494686] Mon, 02 November 2009 05:05 Go to previous messageGo to next message
You could also consider using the plugin_customization.ini file.
HEH
T. Wilhelm a écrit :
> Hi Vincent,
> have a look at the class AbstractPreferenceInitializer, there you can
> set default values to your preferences. Hopes this helps you.
> Greetz,
> Thomas
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Initializing preferences when creating a new workspace [message #495036 is a reply to message #494711] Tue, 03 November 2009 10:32 Go to previous messageGo to next message
Hi Thomas and Mickael,
I didn't have the time to test the AbstractPreferenceInitializer class yet, but here some
comments and questions.
1- The settings I want to initialize are part of the Eclipse plugins not developped by our
company. These settings don't seem to support plugin_customization.ini file.
2- Can I use AbstractPreferenceInitializer class to initialize setting of external plugins
or only the plugin that contains the org.eclipse.core.runtime.preferences extension?
3- Can I generate .metadata\.plugins\org.eclipse.core.runtime\.settings\*.pref file
manually using Eclipse API ? Should I do this in the AbstractPreferenceInitializer class?
Vincent
Re: Initializing preferences when creating a new workspace [message #495037 is a reply to message #494711] Tue, 03 November 2009 10:33 Go to previous messageGo to next message
Vincent
Re: Initializing preferences when creating a new workspace [message #495062 is a reply to message #495036] Tue, 03 November 2009 11:56 Go to previous messageGo to next message
> yet, but here some comments and questions.
> not developped by our company. These settings don't seem to support
Which ones exactly?
Dani
> of external plugins or only the plugin that contains the
> 3- Can I generate
> Vincent
Re: Initializing preferences when creating a new workspace [message #495098 is a reply to message #495062] Tue, 03 November 2009 12:59 Go to previous messageGo to next message
Hi Daniel,
Currently, we only want to initialize the following plugins:
1- org.python.pydev
2- org.python.pydev.debug
3- org.eclipse.tm.terminal.view
For example, in the case of pydev plugins, since we are distributing python application
interpreter with our rcp application, we want to make sure that the pydev plugin are
pre-configurer to use our specific interpreter.
Vincent
Re: Initializing preferences when creating a new workspace [message #495204 is a reply to message #495098] Wed, 04 November 2009 02:35 Go to previous messageGo to next message
Vincent L. wrote:
> Hi Daniel,
> 1- org.python.pydev
You should file a bug report to them if they don't support the
plugin_customization.ini.
Dani
> python application interpreter with our rcp application, we want to
> make sure that the pydev plugin are pre-configurer to use our specific
> interpreter.
> Thanks
> Vincent
Re: Initializing preferences when creating a new workspace [message #495325 is a reply to message #495204] Wed, 04 November 2009 09:39 Go to previous message
Ok thanks.
Vincent
Previous Topic:Confusing PreferenceStore
Next Topic:Views update from application
Current Time: Sun Jul 27 01:58:41 EDT 2025
Powered by FUDForum. Page generated in 0.06887 seconds
