| is sharing the mylyn DB folder between eclipse instances ok? [message #490584] |
Fri, 09 October 2009 05:43  |
my use case is that i have several eclipse workspaces that i need to open concurrently and i would like them to share the same Mylyn DB.
i have tried to do this yesterday and it seems to work.
so far i havent seen any side effect yet and changes in one instance are propagated to the other.
but is this safe?
[Updated on: Fri, 09 October 2009 05:49] by Moderator
| Re: is sharing the mylyn DB folder between eclipse instances ok? [message #494469 is a reply to message #494321] |
Fri, 30 October 2009 14:28   |
Simple solution is to subscribe for some free repository service :-)
For example, hosted FogBugz repository is free for 2 users
(http://www.fogcreek.com/FogBugz/StudentAndStartup.html), and Foglyn,
FogBugz connector for Mylyn, can also be used for free for this FogBugz
edition (http://www.foglyn.com/fogbugz-startups-students.html).
I think it is also possible to find free Trac hosting or some other
repository which will suit your needs.
-Peter
Jason wrote:
> I encounter the similar case.
> I use the Local repository and want to share this tasks and their
> context through different workspaces. These workspace has similar
> projects and codes, i.e, one for maintenance, the 2nd for development.
> Can we have there any options such as new Local repository in eclipse
> instance installation dir, or even to specify a dir, i.e, c:\myRepository
> At least, we should be able to export a task and its context and then
> import it into another local repository. Can't we do that?
> Thanks.
FUDForum. Page generated in 0.03648 seconds
