Home » Modeling » M2T (model-to-text transformation) » XSD & Xpand (for xmt2test)(How to combine XSD with Xpand)
icon5.gif  XSD & Xpand (for xmt2test) [message #494539] Sat, 31 October 2009 05:42 Go to next message
I found a tutorial for XSD and Xpand for oAW 4.3.1. This is exactly what I want to do. But how can I do with the current version integrated in eclipse Galileo?
When I create a Xpand project I do not have the XSD option.
Please help me. This tool combination would be sooo cool.
br,
Marco
Re: XSD & Xpand (for xmt2test) [message #494558 is a reply to message #494539] Sat, 31 October 2009 08:11 Go to previous messageGo to next message
Hello Marco,
there is no problem to create a xml 2 text project using the XSD Adaptor that moved from oAW to Eclipse too.
Here are the Steps you have to do:
  1. Creste a New Xpand Project
  2. Go to your projects Properties and select XSD Metamodels in the Xtend/Xpand Section
  3. place your XSD and XML File somewhere in a Source Folder
  4. Create your workflow (adjust the one from oAW 4.3.1 to the new Classes. The result might look like this
    <workflow>
    	<!-- load the file -->
    	<component class="org.eclipse.xtend.typesystem.xsd.XMLReader">
    		<modelSlot value="model" />
    		<uri value="model/mysetup.xml" />
    		<metaModel id="mm"
    			class="org.eclipse.xtend.typesystem.xsd.XSDMetaModel">
    		</metaModel>
    	</component>
    	<!-- clean up the target directory -->
    	<component
    		class="org.eclipse.emf.mwe.utils.DirectoryCleaner">
    		<directory value="src-gen/mypackage" />
    	</component>
    	<!-- generate some code -->
    	<component class="org.eclipse.xpand2.Generator">
    		<metaModel idRef="mm" />
    		<expand value="templates::wizard::Root FOR model" />
    		<outlet path="src-gen" />
    		<beautifier
    			class="org.eclipse.xpand2.output.JavaBeautifier" />
    	</component>
    </workflow>
  5. adjust your projects dependencies
  6. run the workflow
Re: XSD & Xpand (for xmt2test) [message #494582 is a reply to message #494558] Sat, 31 October 2009 13:42 Go to previous messageGo to next message
Hi Christian,
Thanks for your help.
Still I don't know how to match my template with the names of the workflow and the model.
I start with this template:
«IMPORT metamodel»
«DEFINE Root FOR breakdownXml::BreakdownXmlDocumentRoot»
«FILE "breakdown.xxx"-»
«this.toString()»
BREAKDOWN:
«ENDFILE»
«ENDDEFINE»
and get this error from the workflow:
SEVERE: Error in Component of type org.eclipse.xpand2.Generator:
EvaluationException : No Definition 'template::Template::Root for type::AnyType' found!
[23,41] on line 1 'EXPAND template::Template::Root FOR model'
As you might see I am a complete beginner with XPand and EMF. So please do not hesitate to mention basics.
Pease help me further.
br,
m
Re: XSD & Xpand (for xmt2test) [message #494589 is a reply to message #494582] Sat, 31 October 2009 14:28 Go to previous messageGo to next message
could you please post your workflow / xsd / xml and folder structure.
and check if you use inhertiance in your metamodel - then you have to place the definition for the subtypes as well as for the supertype to match xpands polymorphim requirements
[Updated on: Sat, 31 October 2009 14:32] by Moderator
Re: XSD & Xpand (for xmt2test) [message #494590 is a reply to message #494539] Sat, 31 October 2009 14:59 Go to previous messageGo to next message
src
_model.xml
_metamodel.xsd
_wf.mwe
_template
__Template.xpt
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified">
<xs:element name="root">
<xs:complexType>
<xs:sequence>
<xs:element maxOccurs="unbounded" ref="Breakdown"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="Breakdown">
<xs:complexType>
<xs:sequence>
<xs:element ref="DictDetail_Name"/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="DictDetail_Name">
<xs:complexType>
<xs:simpleContent>
<xs:extension base="xs:NCName">
<xs:attribute name="Type" use="required" type="xs:NCName"/>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
<?xml version="1.0" encoding="ISO-8859-1"?>
<root>
<Breakdown>
<DictDetail_Name Type="String">abc</DictDetail_Name>
</Breakdown>
</root>
<workflow>
<uri value="model.xml" />
<metaModel id="mm"
</metaModel>
</component>
<component
</component>
<expand value="template::Template::Root FOR model" />
<beautifier
</component>
</workflow>
«IMPORT metamodel»
«FILE "breakdown.stm"-»
«this.toString()»
BREAKDOWN:
«ENDFILE»
«ENDDEFINE»
Re: XSD & Xpand (for xmt2test) [message #494591 is a reply to message #494590] Sat, 31 October 2009 15:18 Go to previous messageGo to next message
your root element is a named root that has an anonymous complex type. these types are mapped to the EClass [[elementName]]Type. so in your case the root Element is of type metamodel::RootType and your template should looklike this
«IMPORT metamodel»
«DEFINE Root FOR RootType»
«this.toString()»
BREAKDOWN:
«ENDFILE»
«ENDDEFINE»
fore more information how xsd constructs are mapped to ecore construct have a look at http:// www.eclipse.org/modeling/emf/docs/overviews/XMLSchemaToEcore Mapping.pdf
Re: XSD & Xpand (for xmt2test) [message #494592 is a reply to message #494591] Sat, 31 October 2009 15:34 Go to previous messageGo to next message
The result has not changed.
So still
does not match
«DEFINE Root FOR metamodel::RootType» (also tried just RootType)
/m
Re: XSD & Xpand (for xmt2test) [message #494595 is a reply to message #494592] Sat, 31 October 2009 16:57 Go to previous messageGo to next message
yes the other thing is that you xml should use xsd / refer to xsd
therefore the xsd should look like this
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<xs:schema xmlns="http://www.example.org/test" xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://www.example.org/test">
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:simpleContent>
<xs:attribute name="Type" type="xs:NCName" use="required"/>
</xs:extension>
</xs:simpleContent>
</xs:complexType>
</xs:element>
</xs:schema>
and the xml like this
<root xmlns="http://www.example.org/test"
	xsi:schemaLocation="http://www.example.org/test metamodel.xsd ">
<Breakdown>
</Breakdown>
</root>
or try the other possibilities described at http:// help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.xpand. doc/help/ch04s05.html
Re: XSD & Xpand (for xmt2test) [message #494597 is a reply to message #494539] Sat, 31 October 2009 17:24 Go to previous messageGo to next message
Thanks again for the suggestion.
I tried it all, except the import variant, but the result is still the same.
There is no message about a missing xsd.
Any more ideas?
br,
m
Re: XSD & Xpand (for xmt2test) [message #494599 is a reply to message #494539] Sat, 31 October 2009 17:32 Go to previous messageGo to next message
could you please share a sample project, i tried your template and workflow with the xsd and xml i shared and it work wonderful
(see attachment)
[Updated on: Sat, 31 October 2009 17:56] by Moderator
Re: XSD & Xpand (for xmt2test) [message #494605 is a reply to message #494539] Sat, 31 October 2009 20:40 Go to previous messageGo to next message
Hope the attached project archive helps to identify the problem.
br,
m
[Updated on: Sat, 31 October 2009 20:44] by Moderator
Re: XSD & Xpand (for xmt2test) [message #494606 is a reply to message #494605] Sat, 31 October 2009 20:46 Go to previous messageGo to next message
The upload does not work despite the archive is smaller than 2MB.
How can I send you?
/m
Re: XSD & Xpand (for xmt2test) [message #494624 is a reply to message #494606] Sun, 01 November 2009 06:32 Go to previous messageGo to next message
try something like drop.io
Re: XSD & Xpand (for xmt2test) [message #494625 is a reply to message #494624] Sun, 01 November 2009 06:37 Go to previous messageGo to next message
Hi Christian,
Thx for another useful hint.
http://drop.io/0shwh6u
br
m
Re: XSD & Xpand (for xmt2test) [message #494628 is a reply to message #494625] Sun, 01 November 2009 06:54 Go to previous messageGo to next message
hi, of course you have to class the right template from your workflow. in your case this might look like this
		<beautifier
	</component>
and you have to add some additional dependency
  • com.ibm.icu
Re: XSD & Xpand (for xmt2test) [message #494648 is a reply to message #494628] Sun, 01 November 2009 12:55 Go to previous messageGo to next message
Hi Christian,
Thank you for finding the problem, and proofing my blindness Wink
br
m
Re: XSD & Xpand (for xmt2test) [message #498087 is a reply to message #494539] Sat, 14 November 2009 06:39 Go to previous message
Hi Christian,
Would you please help me another time with a maybe similar problem. -> Thread: http://www.eclipse.org/forums/index.php?t=msg&goto=49808 4&
br
Marco
Previous Topic:How to escape "<",">" in jet2?
Next Topic:XSD adapter and imports
Current Time: Fri Sep 19 06:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.05865 seconds
