Home » Eclipse Projects » Plugin Development Environment (PDE) » Building org.eclipse.epp.package.java
Building org.eclipse.epp.package.java [message #494375] Fri, 30 October 2009 09:06 Go to next message
(Apologies for cross-posting. Trying eclipse.platform.pde as
eclipse.platform.packaging seems to be unattended... If this is not a
suitable newsgroup for this post either, any advice on where I could try
next would be highly appreciated.)
Hi all,
I'm trying to build an Eclipse distribution using the
org.eclipse.epp.package.java product (using 3.5.1).
First, I checked out the org.eclipse.epp.package.java and
org.eclipse.epp.package.java.feature projects from the CVS
(org.eclipse.epp/packages), in my workspace.
Then, I used the P2 mirroring application to create a local mirror of
the 3.5 repository under
D:\Projects\epp\workspace\org.modelplex.platform.epp.mirrors \galileo
Now, I'm trying to run the P2 Director application (as per
http://wiki.eclipse.org/EPP/Galileo_Packages) with the following
arguments (via Run Configurations->Eclipse Application)
Program arguments:
-consoleLog
-m
file://D:/Projects/epp/workspace/org.modelplex.platform.epp. mirrors/galileo/
-a
-installIU epp.package.java
-destination d:/temp
-profile epp.package.java
-flavor tooling
-profileProperties org.eclipse.update.install.features=true
-bundlepool d:/temp
-p2.os linux -p2.ws gtk -p2.arch x86_64
-roaming
Vm arguments:
-Declipse.p2.mirrors=false -Declipse.p2.data.area=d:temp/eclipse/p2
Running this configuration fails with the following error:
"The installable unit epp.package.java has not been found"
How should I configure/run the director application so that it can find it?
Dimitris
Re: Building org.eclipse.epp.package.java [message #494393 is a reply to message #494375] Fri, 30 October 2009 10:09 Go to previous messageGo to next message
You are missing the metadata for the "epp.package.java" itself.
Depending on what your actually doing, you can just mirror that from
here (I think) http://download.eclipse.org/technology/epp/packages/galileo/
In this case you don't need the stuff from CVS.
OR, you can build the stuff you checked out of CVS.
I'm not sure the details of building the package, you can try setting up
your own product build on the .product file, or there is also
org.eclipse.epp/rleeng/org.eclipse.epp.pde.build which seems to contain
scripts that might do it for you (see build-pde.xml).
-Andrew
> Hi all,
> Program arguments:
> -consoleLog
> -m
> -a
> -flavor tooling
> -bundlepool d:/temp
> -roaming
> Vm arguments:
> Cheers,
> Dimitris
Re: Building org.eclipse.epp.package.java [message #494407 is a reply to message #494393] Fri, 30 October 2009 10:34 Go to previous messageGo to next message
Hi Andrew,
Many thanks for your reply! I mirrored
http://download.eclipse.org/technology/epp/packages/galileo/ to a local
repository
(D:\Projects\epp\workspace\org.modelplex.platform.epp.mirror s\galileopackages)
and added the local repository to the metadataRepository and
artefactRepository parameters in my launch configuration as follows:
-consoleLog
-metadataRepository
file:///D:/Projects/epp/workspace/org.modelplex.platform.epp .mirrors/galileo/,file:///D:/Projects/epp/workspace/org.mode lplex.platform.epp.mirrors/galileopackages/
-artifactRepository
-installIU epp.product.java
-profile epp.product.java
-flavor tooling
-bundlepool d:/temp
-roaming
but I'm getting the same error. Any thoughts on what I should try next?
Dimitris
> -Andrew
>> Hi all,
>> Program arguments:
>> -consoleLog
>> -m
>> -a
>> -flavor tooling
>> -bundlepool d:/temp
>> -roaming
>> Vm arguments:
>> find it?
>> Cheers,
>> Dimitris
Re: Building org.eclipse.epp.package.java [message #494489 is a reply to message #494407] Fri, 30 October 2009 16:23 Go to previous messageGo to next message
Hi Andrew,
I think I should be mirroring
http://download.eclipse.org/technology/epp/packages/galileo/ SR1/
instead. I'll try that and get back to you if the problem persists.
Dimitris
> Hi Andrew,
> repository
> -consoleLog
> -metadataRepository
> -artifactRepository
> -flavor tooling
> -bundlepool d:/temp
> -roaming
> Cheers,
> Dimitris
>> here (I think)
>> up your own product build on the .product file, or there is also
>> contain scripts that might do it for you (see build-pde.xml).
>> -Andrew
>>> Hi all,
>>> Program arguments:
>>> -consoleLog
>>> -m
>>> -a
>>> -flavor tooling
>>> -bundlepool d:/temp
>>> -roaming
>>> Vm arguments:
>>> find it?
>>> Cheers,
>>> Dimitris
Re: Building org.eclipse.epp.package.java [message #494746 is a reply to message #494489] Mon, 02 November 2009 08:45 Go to previous message
Hi Andrew,
I've made some progress but still no cigar. I've had to copy the
contents of technology/epp/packages/galileo/SR1 from
download1.eclipse.org as the mirroring application would not create the
correct artifacts.jar/content.jar (for some reason).
Now I've got past the epp.package.java error on to the next one:
Missing requirement: EPP Java Package 1.2.1.20090918-0703
(org.eclipse.epp.package.java.feature.feature.group 1.2.1.20090918-0703)
requires 'org.eclipse.epp.usagedata.feature.feature.group 0.0.0' but it
could not be found
Any thoughts on this? What I'm really trying to do is to reproduce the
Java package so that I have a working example on which I can then build
a custom distribution.
Dimitris
> Hi Andrew,
> Cheers,
> Dimitris
>> Hi Andrew,
>> local repository
>> -consoleLog
>> -metadataRepository
>> -artifactRepository
>> -flavor tooling
>> -bundlepool d:/temp
>> -roaming
>> Cheers,
>> Dimitris
>>> here (I think)
>>> -Andrew
>>>> try
>>>> Hi all,
>>>> Program arguments:
>>>> -consoleLog
>>>> -m
>>>> -a
>>>> -flavor tooling
>>>> -bundlepool d:/temp
>>>> -roaming
>>>> Vm arguments:
>>>> find it?
>>>> Cheers,
>>>> Dimitris
Re: Building org.eclipse.epp.package.java [message #603040 is a reply to message #494375] Fri, 30 October 2009 10:09 Go to previous message
-Andrew
> Hi all,
> Program arguments:
> -consoleLog
> -m
> -a
> -flavor tooling
> -bundlepool d:/temp
> -roaming
> Vm arguments:
> Cheers,
> Dimitris
Re: Building org.eclipse.epp.package.java [message #603043 is a reply to message #494393] Fri, 30 October 2009 10:34 Go to previous message
Hi Andrew,
repository
-consoleLog
-metadataRepository
-artifactRepository
-flavor tooling
-bundlepool d:/temp
-roaming
Dimitris
> -Andrew
>> Hi all,
>> Program arguments:
>> -consoleLog
>> -m
>> -a
>> -flavor tooling
>> -bundlepool d:/temp
>> -roaming
>> Vm arguments:
>> find it?
>> Cheers,
>> Dimitris
Re: Building org.eclipse.epp.package.java [message #603048 is a reply to message #494407] Fri, 30 October 2009 16:23 Go to previous message
Hi Andrew,
Dimitris
> Hi Andrew,
> repository
> -consoleLog
> -metadataRepository
> -artifactRepository
> -flavor tooling
> -bundlepool d:/temp
> -roaming
> Cheers,
> Dimitris
>> here (I think)
>> -Andrew
>>> Hi all,
>>> Program arguments:
>>> -consoleLog
>>> -m
>>> -a
>>> -flavor tooling
>>> -bundlepool d:/temp
>>> -roaming
>>> Vm arguments:
>>> find it?
>>> Cheers,
>>> Dimitris
Re: Building org.eclipse.epp.package.java [message #603062 is a reply to message #494489] Mon, 02 November 2009 08:45 Go to previous message
Hi Andrew,
could not be found
Dimitris
> Hi Andrew,
> Cheers,
> Dimitris
>> Hi Andrew,
>> local repository
>> -consoleLog
>> -metadataRepository
>> -artifactRepository
>> -flavor tooling
>> -bundlepool d:/temp
>> -roaming
>> Cheers,
>> Dimitris
>>> here (I think)
>>> -Andrew
>>>> try
>>>> Hi all,
>>>> Program arguments:
>>>> -consoleLog
>>>> -m
>>>> -a
>>>> -flavor tooling
>>>> -bundlepool d:/temp
>>>> -roaming
>>>> Vm arguments:
>>>> find it?
>>>> Cheers,
>>>> Dimitris
Previous Topic:How do i lock a toolbar in an extension point?
Next Topic:Getting position (Point) of text cursor in editor
Current Time: Sat Jul 26 11:12:06 EDT 2025
Powered by FUDForum. Page generated in 0.11625 seconds
