Home » Eclipse Projects » Plugin Development Environment (PDE) » New Target Platform Definition and Export to Multiple Platforms
New Target Platform Definition and Export to Multiple Platforms [message #49318] Thu, 05 March 2009 03:45 Go to next message
It seems I can't export to multiple platforms when using the new
(experimental) target platform definition. Is there anything special to
do? I installed the Delta Pack in both, the host and the target
platform, but when I export the product, there is no option to export
to multiple platforms. If I don't use the new (experimental) target
platform preference page, but the old one, then everything works fine,
I get the option in the export wizard and can export to multiple
platforms.
Is there anything special I need to do?
I'm working with OSX cocoa 3.5M5.
Marc
Re: New Target Platform Definition and Export to Multiple Platforms [message #49439 is a reply to message #49318] Thu, 05 March 2009 10:12 Go to previous message
Marc Moser wrote:
> platform, but when I export the product, there is no option to export to
> platform preference page, but the old one, then everything works fine, I
> get the option in the export wizard and can export to multiple platforms.
If you're using the deltapack, you must add it via the "Directory"
option when adding bundle containers. That should work for you. If not,
please let us know. We are doing some work in 3.5M6 to make this a bit
easier when working with the delta pack, things are still a work in
progress so thanks for your patience :)
Any feedback on improving the tooling is appreciated also!
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: New Target Platform Definition and Export to Multiple Platforms [message #592838 is a reply to message #49318] Thu, 05 March 2009 10:12 Go to previous message
Marc Moser wrote:
Previous Topic:Export Wizard fails
Next Topic:Contributed Ant task, headless behaviour changed 3.3.2 -> 3.5M5
Current Time: Mon Nov 03 16:19:10 EST 2025
Powered by FUDForum. Page generated in 0.04179 seconds
