Home » Archived » Buckminster » Problem resolving JAXB compontents from maven repository
Problem resolving JAXB compontents from maven repository [message #494166] Thu, 29 October 2009 09:06 Go to next message
I have a small java 1.5 project that depends on JAXB. In my *.rmap a
maven provider exists with uri="http://repo1.maven.org/maven2".
Unfortunately, when materializing the project, buckminster is unable to
locate "jaxb-api.jar".
In the project I have the following included in my buckminster.cspex:
<cs:dependencies>
<cs:dependency name="com/sun/xml/bind/jaxb-xjc"
versionDesignator="2.1.9" versionType="String" componentType="jar" />
<cs:dependency name="com/sun/xml/bind/jaxb-impl"
<cs:dependency name="javax/xml/bind/jaxb-api" versionDesignator="2.2"
<cs:dependency name="stax/stax-api" versionDesignator="1.0.1"
<cs:dependency name="javax/xml/bind/activation"
versionDesignator="1.0.2" versionType="String" componentType="jar" />
<cs:dependency name="com/sun/xml/messaging/saaj/saaj-impl"
versionDesignator="1.3.2" versionType="String" componentType="jar" />
I have experimented with the versionDescriptors und versionTypes without
success. If I don't give any version Information an old version (I
believe it's 2.0) of jaxb-api.jar is downloaded. Buckminster doesn't
complain in that case, but JAXB doesn't work, because of the
incompatible jaxb-api.jar.
How do I get buckminster to download all the components in the correct
version? An IdeaI had, was to create an alternative URL provider to the
maven repository, since I "know" the exact URL to all of the components.
The construction of the url would look like this:
baseURL("http://repo1.maven.org/maven2/") +
componentName("javax/xml/bind/jaxb-api") + "/" + version("2.2") + "/" +
filename(jaxb-api) + "-" + version("2.2") + ".jar"
But I do not know if this is a good idea and how it's done.
Thanks for your help
Damian
Re: Problem resolving JAXB compontents from maven repository [message #494179 is a reply to message #494166] Thu, 29 October 2009 09:36 Go to previous messageGo to next message
Hi Damian,
The names of your dependencies seems a bit wrong. You're supposed to use the slash to separate the
groupId from the artifactId. So just one slash in a name.
I also suggest that you use the Triplet version instead of the String version when accessing a Maven
repository.
Thomas Hallgren
Damian Hofmann wrote:
> Hi
> <cs:dependencies>
> versionDesignator="2.2" versionType="String" componentType="jar" />
> Damian
Re: Problem resolving JAXB compontents from maven repository [message #494206 is a reply to message #494179] Thu, 29 October 2009 10:25 Go to previous messageGo to next message
Thanks Thomas,
So instead of
I have to write
<cs:dependency name="javax.xml.bind/jaxb-api" versionDesignator="2.2"
versionType="Tripple" componentType="jar" />
right?
I still get the same error message:
ERROR [0003] : No suitable provider for component
javax.xml.bind/jaxb-api:jar/2.2#Triplet was found in resourceMap
file:/Users/arbeit/Workspaces/autorentool/ag.leonardo.releng /leonardo.rmap
Damian
Thomas Hallgren schrieb:
> Hi Damian,
> the slash to separate the groupId from the artifactId. So just one slash
> in a name.
> version when accessing a Maven repository.
> Regards,
> Thomas Hallgren
>> Hi
>> to locate "jaxb-api.jar".
>> <cs:dependencies>
>> without success. If I don't give any version Information an old
>> version (I believe it's 2.0) of jaxb-api.jar is downloaded.
>> Buckminster doesn't complain in that case, but JAXB doesn't work,
>> because of the incompatible jaxb-api.jar.
>> the maven repository, since I "know" the exact URL to all of the
>> components.
>> + filename(jaxb-api) + "-" + version("2.2") + ".jar"
>> Damian
Re: Problem resolving JAXB compontents from maven repository [message #494207 is a reply to message #494206] Thu, 29 October 2009 11:01 Go to previous messageGo to next message
> Thanks Thomas,
> So instead of
> I have to write
> right?
Yes, almost. It's "Triplet", not "Tripple" and the component type should be "maven".
Did you install the Buckminster Maven feature?
If you did, please set the console log level to DEBUG (Buckminster preferences) and try again. The
output may give you some hints.
If you can't find the source of the problem, please include the relevant parts of your rmap so that
I can review them.
- thomas
Re: Problem resolving JAXB compontents from maven repository [message #494230 is a reply to message #494207] Thu, 29 October 2009 12:30 Go to previous messageGo to next message
>> So instead of
>> I have to write
>> right?
> be "maven".
OK, tried that. Now the error massage has changed. When materializing I
get a messagebox, saying:
'Materializing' has encoutered a problem.
Attempt to use an unresolved node. Request is
javax.xml.bind/jaxb-api:maven/[2.1,2.1]#Triplet
On console (loglevel set to debug) buckminster writes:
ERROR [0019] : No suitable provider for component
javax.xml.bind/jaxb-api:maven/[2.1,2.1]#Triplet was found in resourceMap
javax.xml.bind/jaxb-api:maven/[2.1,2.1]#Triplet was found in searchPath
org.eclipse.platform.RBUILD
ERROR [0019] : Rejecting provider
eclipse.import( http://download.eclipse.org/eclipse/updates/3.5?importType=b inary):
Components of type maven are not supported
org.eclipse.galileo
eclipse.import( http://download.eclipse.org/releases/galileo?importType=bina ry):
maven
maven2(http://repo1.maven.org/maven2): No component match was found
What irritates me is, that buckminster is looking for JAXB 2.1 but JAXB
2.2 is specified.
My rmap looks like this:
<rmap
<searchPath name="maven">
<provider xsi:type="mp:MavenProvider" readerType="maven2"
componentTypes="maven,jar" mutable="false" source="false">
<uri format="http://repo1.maven.org/maven2" />
</provider>
</searchPath>
<locator searchPathRef="maven" failOnError="false" />
</rmap>
Damian
Re: Problem resolving JAXB compontents from maven repository [message #494373 is a reply to message #494230] Fri, 30 October 2009 09:04 Go to previous messageGo to next message
Hi Thomas
I still have problems with buckminster. It seems that buckminster
downloads now most components but still has troubles with resolving
jaxb-api. Maybe the problem is, that the version isn't realy a Triplet.
As an workaround I have added a new locator to my rmap, that locates the
requestet jar as an url.
This looks like this:
<searchPath name="jaxb-api">
<provider readerType="url" componentTypes="jar" mutable="false"
source="false">
<uri
format=" http://repo1.maven.org/maven2/javax/xml/bind/jaxb-api/2.2/ja xb-api-2.2.jar"
</provider>
</searchPath>
<locator searchPathRef="jaxb-api" failOnError="false"
pattern="^javax\.xml\.bind\/jaxb\-api(.+)?" />
Buckminster seems to do a lot of work now, but finaly I'm getting an
error message again, complaining about a missing .project-file for the
..buckminster-project.
What does it mean? How to solve that. Or am I following a death track
with this workaround anyway?
Greets Damian
Damian Hofmann schrieb:
>>> So instead of
>>> I have to write
>>> right?
>> should be "maven".
> org.eclipse.galileo
> maven
> 2.2 is specified.
> <rmap
> </provider>
> </searchPath>
> </rmap>
> Damian
Re: Problem resolving JAXB compontents from maven repository [message #494532 is a reply to message #494230] Sat, 31 October 2009 04:35 Go to previous message
Hi Damian,
I suggest you take a look at the http://repo2.maven.org/maven2/javax/xml/bind/jaxb-api/maven- metadata.xml
It contains the following:
<metadata>
<groupId>javax.xml.bind</groupId>
<artifactId>jaxb-api</artifactId>
<version>2.0</version>
<versioning>
<versions>
<version>1.0</version>
</versions>
</versioning>
</metadata>
I don't see a version 2.2 in there. Perhaps someone forgot to update the meta-data or perhaps the newer versions are not
considered stable? I suggest you pop the question to the people responsible for the repository.
Regarding asking for 2.1, I don't really understand that and I can't reproduce it. When I test this, I get requests for
2.2 if that's what I have in the query. Are you asking for some other component and see this in the transitive
resolution? If that's the case, then try putting a check mark in "Continue on error", click "Resolve..." and then save
the resulting BOM. You can view it with the dependency viewer and see what component it is that requests version 2.1.
I tried resolving version 2.0 with your rmap and that works just fine.
Thomas Hallgren
On 10/29/2009 05:30 PM, Damian Hofmann wrote:
>>> So instead of
>>> I have to write
>>> right?
>> should be "maven".
> org.eclipse.galileo
> maven
> ERROR [0019] : Rejecting provider maven2(http://repo1.maven.org/maven2):
> 2.2 is specified.
> <rmap
> </provider>
> </searchPath>
> </rmap>
> Damian
Previous Topic:aggregator editor on eclipse 3.5.1
Next Topic:NullPointerException when bundle depends on the system bundle
Current Time: Sun Aug 31 21:27:18 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
