Home » Archived » BIRT » WebViewer in RCP and relative path flatfile
icon3.gif  WebViewer in RCP and relative path flatfile [message #494181] Thu, 29 October 2009 09:53 Go to next message
we have a RCP application based on eclipse. Inside the workspace the user have reports and the flatfiles for that reports.
Normally the flatfile datasource has an absolute folder, but that doesn't work because of different places of the workspace.
So we would like to go on with relative paths. In a webapplication that is not a problem, when the report-files are inside the webapplication. The we use the script in beforeOpen of the datasource:
var rp = reportContext.getHttpServletRequest().getSession().getServle tContext().getRealPath( "/");
this.setExtensionProperty("HOME", rp);
But how to use that in the WebViewer? How is the best way to do that. At the moment we use that to view the reports:
WebViewer.display(report, browser, params);
Re: WebViewer in RCP and relative path flatfile [message #494233 is a reply to message #494181] Thu, 29 October 2009 12:44 Go to previous messageGo to next message
Martin,
Can you try something like:
Bundle bundle = org.eclipse.core.runtime.Platform.getBundle("myrcpapp");
URL url = FileLocator.find(bundle, new
Path("/reports/myffreport.rptdesign"), null);
String rpt = FileLocator.toFileURL(url).getPath();
Jason
Martin Schmitz wrote:
> Hello,
> Thanks
Re: WebViewer in RCP and relative path flatfile [message #494250 is a reply to message #494233] Thu, 29 October 2009 13:56 Go to previous messageGo to next message
Jason,
when I understand you code right, it is for finding the report-file in my application. That is not the problem, because the user double clicks the file for opening the report.
I start the WebViewer with this code:
IFileEditorInput input = (IFileEditorInput) getEditorInput();
IFile file = input.getFile();
String report = file.getLocation().makeAbsolute().toOSString();
if (report.length() != 0) {
Map<String, Object> params = new HashMap<String, Object>();
params.put(WebViewer.RESOURCE_FOLDER_KEY, "C:/Temp/");
params.put(WebViewer.SERVLET_NAME_KEY, "run");
params.put(WebViewer.FORMAT_KEY, WebViewer.HTML);
The report is: C:/Workspace/Reports/MyLittleReport.rptdesign
The data is C:/Workspace/Reports/Data/mydata.csv
The blue path is choosen by the user and may be different. How to set the datasource via JavaScript, when I only know that it is relative to the report in the folder data. Due the report is not inside an application server I think I am not able to find out the path to the file and even to the datafile by jacascript, right?. Is there a way to pass the path of the report to the webviewer and then receiving that variable in javascript datasource.beforeopen?
Martin
Re: WebViewer in RCP and relative path flatfile [message #494270 is a reply to message #494250] Thu, 29 October 2009 17:10 Go to previous messageGo to next message
Martin,
Pardon my confusion :>
You have a couple of choices:
1 - call the plugin code from script like in the beforeFactory
importPackage(Packages.org.eclipse.core.runtime);
mybundle = Platform.getBundle("org.eclipse.birt.report.viewer");
furl = FileLocator.find(mybundle, new Path("/birt/webcontent"), null);
//you may have to trim leading slash
myfolder = FileLocator.toFileURL(furl).getPath();
or
2 - Implement the appcontext extension and preload the path into the
appcontext.
In your code before calling display (Note that viewer code has not been
updated yet for new preference scheme so use deprec. call.
//new DefaultScope().getNode("").put("APPCONTEXT_EXTENSION_KEY",
"MyAppContext");
//String appContextName =
Platform.getPreferencesService().getString("org.eclipse.birt.viewer ",
"APPCONTEXT_EXTENSION_KEY", "", null);
//WebViewer has not been updated to use new preferences scheme
String appContextName = ViewerPlugin.getDefault(
).getPluginPreferences( ).getString( "APPCONTEXT_EXTENSION_KEY" );
ViewerPlugin.getDefault( ).getPluginPreferences(
).setValue("APPCONTEXT_EXTENSION_KEY", "MyAppContext");
example MyAppContext
package org.eclipse.birt.examples.rcpviewer;
import java.util.Map;
import org.eclipse.birt.report.viewer.api.AppContextExtension;
public class MyAppContext extends AppContextExtension{
public Map getAppContext(Map appContext) {
Map hm = super.getAppContext(appContext);
hm.put("PARENT_CLASSLOADER", PreviewBirtAction.class.getClassLoader());
return hm;
public String getName() {
// TODO Auto-generated method stub
return "MyAppContext";
Put anything you want in the context and then in an expression or script
call
reportContext.getAppContext().get("whateveruputin");
Jason
> Jason,
> Martin
Re: WebViewer in RCP and relative path flatfile [message #494381 is a reply to message #494181] Fri, 30 October 2009 09:50 Go to previous messageGo to next message
Jason,
thank you for the help. I decided pro alternativ 2, but there is one problem. The path, I am setting if fix, once I have set it.
I think, there is only one way to get the datasource folder variable. I will reading the report, add a parameter, that is invisible to users, with the path of the folder and then change "HOME" of the datasource to that folder and the save the report as emporaryfile.
That should be the easiest way to handle that problem?
Martin
Re: WebViewer in RCP and relative path flatfile [message #494397 is a reply to message #494381] Fri, 30 October 2009 10:01 Go to previous messageGo to next message
Martin,
That should work. I was trying to come up with an alternative to adding
a report parameter.
Jason
> Jason,
> Martin
Re: WebViewer in RCP and relative path flatfile [message #495253 is a reply to message #494397] Wed, 04 November 2009 06:17 Go to previous messageGo to next message
Here is my solution.
Starting the report from RCP
private void previewReport() {
		try {
			WebViewer.stopAll();
			String report = "";
			DesignConfig config = new DesignConfig();
			IDesignEngine engine = null;
			try {
				ReportDesignHandle designHandle = null;
				ElementFactory designFactory = null;
				Platform.startup(config);
				IDesignEngineFactory factory = (IDesignEngineFactory) Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
				engine = factory.createDesignEngine(config);
				SessionHandle session = engine.newSessionHandle(ULocale.ENGLISH);
				// open a design or a template
				designHandle = session.openDesign(file.getLocation().makeAbsolute().toOSString());
				designFactory = designHandle.getElementFactory();
				ScalarParameterHandle sph = designFactory.newScalarParameter("REPORT_PATH");
				List<String> defaultValue = new ArrayList<String>();
				defaultValue.add(file.getParent().getLocation().makeAbsolute().toOSString());
				sph.setDefaultValueList(defaultValue);
				sph.setProperty(ScalarParameterHandle.HIDDEN_PROP, "true");
				sph.setProperty(ScalarParameterHandle.VALUE_TYPE_PROP, "static");
				sph.setProperty(ScalarParameterHandle.IS_REQUIRED_PROP, "false");
				sph.setProperty(ScalarParameterHandle.DATA_TYPE_PROP, "string");
				sph.setProperty(ScalarParameterHandle.DISTINCT_PROP, "true");
				sph.setProperty(ScalarParameterHandle.PARAM_TYPE_PROP, "simple");
				sph.setProperty(ScalarParameterHandle.CONTROL_TYPE_PROP, "text-box");
				designHandle.getParameters().add(sph);
				report = File.createTempFile("report", ".rptdesign").getAbsolutePath();
				designHandle.saveAs(report); //$NON-NLS-1$
				designHandle.close();
			catch (Exception ex) {
				ex.printStackTrace();
				// params.put(WebViewer.REPORT_DEBUT_MODE, "yes");
		catch (Exception e) {
			PlugIn.log(e);
Here is the code in the reports beforeOpen in datasource:
if( reportContext.getHttpServletRequest() == null ){
else if( reportContext.getHttpServletRequest().getAttribute("attributeBean") == null ){
else if( reportContext.getHttpServletRequest().getAttribute("attributeBean").isDesigner() ){
else{
	var rp =reportContext.getParameterValue( "REPORT_PATH" ) +"/DATA";
	this.setExtensionProperty("HOME",rp);
Re: WebViewer in RCP and relative path flatfile [message #495320 is a reply to message #495253] Wed, 04 November 2009 10:06 Go to previous message
Martin,
This looks good.
Jason
> try {
> String report = "";
> try {
> Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_ DESIGN_ENGINE_FACTORY);
> designHandle =
> session.openDesign(file.getLocation().makeAbsolute().toOSStr ing());
> defaultValue.add(file.getParent().getLocation().makeAbsolute ().toOSString());
> "static");
> "false");
> "string");
> "true");
> "simple");
> "text-box");
> PlugIn.log(e);
> else if(
> reportContext.getHttpServletRequest().getAttribute("attributeBean ") ==
> null ){
> else if(
> reportContext.getHttpServletRequest().getAttribute("attributeBean ").isDesigner()
> else{
Previous Topic:Formatting - Programatically setting style properties
Next Topic:Report design - dynamic date formats
Current Time: Wed Jul 02 21:08:32 EDT 2025
Powered by FUDForum. Page generated in 0.25163 seconds
