Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Generate emtl file without acceleo nature?
[Acceleo] Generate emtl file without acceleo nature? [message #494221] Thu, 29 October 2009 11:57 Go to next message
I like to invoke the AcceleoService on template code without using the acceleoBuilder in the .project file. In other words, I like to manually invoke the acceleo compiler on the template code via API calls.
How can I generate the emtl file based on the template code (typically avaiable in a mtl file)?
Many thanks in advance.
Re: [Acceleo] Generate emtl file without acceleo nature? [message #494307 is a reply to message #494221] Fri, 30 October 2009 04:02 Go to previous message
--------------060807000903090406050806
Hi Markus,
You can take a look at the unit tests code, as we call the parser from
code to avoid cluttering these tests with emtl files. Specifically,
org.eclipse.acceleo.engine.tests.unit.AbstractAcceleoTest#pa rse(String)
is in charge of the parsing and emtl file creation.
Laurent Goubet
Obeo
Marcus a écrit :
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------060807000903090406050806--
Previous Topic:Use case specification and transformation
Next Topic:How JET compares with XSLT?
Current Time: Fri Jul 18 00:43:56 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
