Possible bug in UML2 Genmodel [message #493180] |
Fri, 23 October 2009 09:57  |
Originally posted by: florianwendland.freenet.de
Hi all,
just found a bug in the UML2 genmodel, when the code for an Ecore model,
which was imported from UML2 model, is generated. In fact, when you
going to subset a derived subset association end, the generator inserts
a EObject(Resolving)EList instead of a
SubsetSupersetEObjectResolvingEList. I changed it manually and it works
as supposed.
May i raise an issue at bugzilla?
Marc-Florian
Re: Possible bug in UML2 Genmodel [message #628014 is a reply to message #493180] |
Thu, 29 October 2009 10:53  |
Yes please go ahead and raise any bugzilla you see fit.
Please add more details in the bugzilla and possibly an example. From the
description below I'm not sure I fully understand whether there is an acutal
issue or not.
- James.
"Marc-Florian Wendland" <florianwendland@freenet.de> wrote in message
news:hbscog$atc$1@build.eclipse.org...
> Hi all,
> which was imported from UML2 model, is generated. In fact, when you going
> to subset a derived subset association end, the generator inserts a
> EObject(Resolving)EList instead of a SubsetSupersetEObjectResolvingEList.
> I changed it manually and it works as supposed.
> Marc-Florian
FUDForum. Page generated in 0.07736 seconds
