Home » Eclipse Projects » Plugin Development Environment (PDE) » Use of eclipse.buildScript, need help!!
icon9.gif  Use of eclipse.buildScript, need help!! [message #493919] Wed, 28 October 2009 10:00 Go to next message
Hi !
I'm trying to generate a build.xml file for à plugin from a ant script.
Here's my script:
<project name="generateBuildFiles" default="createBuildFile">
<target name="createBuildFile">
<eclipse.buildScript elements="plugins@my.project.to.build"
buildDirectory="/home/........./myWorkspace" />
</target>
</project>
I call this ant script by the command:
export LAUNCHER_PLUGIN_PATH=$ECLIPSE_INSTALL_DIR/plugins/org.eclips e.equinox.launcher_1.0.101.R34x_v20081125.jar
java -jar $LAUNCHER_PLUGIN_PATH -application org.eclipse.ant.core.antRunner -v -buildfile ./generateBuildFiles.xml
I have the following trace:
Buildfile: /home/........../generateBuildFiles.xml
createBuildFile:
BUILD SUCCESSFUL
Total time: 160 milliseconds
But nothing change in my plugin directtory nor my workspace Mad
Any idea ?
My aim is to have a jar file for my plugin from a command line script.
Thanks!
[Updated on: Wed, 28 October 2009 10:01] by Moderator
Re: Use of eclipse.buildScript, need help!! [message #493970 is a reply to message #493919] Wed, 28 October 2009 11:52 Go to previous messageGo to next message
The element attribute needs to be "plugin@..." not "plugins".
Also:
- The "my.project.to.build" needs to be the Bundle-SymbolicName, not the
project name.
- You need to provide the location of all the other bundles that your
bundle will transitively require. Generally, setting the attribute
baseLocation="${eclipse.home}" might be enough.
valerossi46 wrote:
> Hi !
> Here's my script:
> <eclipse.buildScript elements="mailto:plugins@my.project.to.build"
> </target>
> </project>
> createBuildFile:
> BUILD SUCCESSFUL
> But nothing change in my plugin directtory nor my workspace :x Any idea ?
> Thanks!
Re: Use of eclipse.buildScript, need help!! [message #493988 is a reply to message #493970] Wed, 28 October 2009 12:32 Go to previous message
It works !!! Cool Cool
It was just this "s" after plugin....... Embarrassed
Thanks a lot Andrew!!
Re: Use of eclipse.buildScript, need help!! [message #602989 is a reply to message #493919] Wed, 28 October 2009 11:52 Go to previous message
Also:
project name.
valerossi46 wrote:
> Hi !
> Here's my script:
> </target>
> </project>
> createBuildFile:
> BUILD SUCCESSFUL
> Thanks!
Re: Use of eclipse.buildScript, need help!! [message #603001 is a reply to message #493970] Wed, 28 October 2009 12:32 Go to previous message
It works !!! 8) 8)
It was just this "s" after plugin....... :blush:
Previous Topic:p2.gathering causing target does not exist error
Next Topic:Use eclipsec.exe when building headless RCP
Current Time: Sun Jul 20 21:24:21 EDT 2025
Powered by FUDForum. Page generated in 0.05384 seconds
