Home » Eclipse Projects » Plugin Development Environment (PDE) » Question about buildDirectory and pluginPath
Question about buildDirectory and pluginPath [message #493648] Tue, 27 October 2009 09:21 Go to next message
Hey everyone,
i'm currently writing ant scripts to run a feature based headless build on a rcp application.
Now I have a small question about the properties "buildDirectory" and "pluginPath".
First, the buildDirectory specifies the location of the plugins/features, so they have to be located in buildDirectory/plugins and buildDirectory/features.
The problem now is, that i have splitted up the plugins and features in my buildDirectory. The core plugins/features are in the normal plugins/features directories and the plugins for testing are located for example in "plugins_test". Now i want to build all of the features/plugins, but to do this, i currently have to copy the plugins/features from "plugins_test" to "plugins" and so on, in order to get them built. Is there an easier way to do this and avoiding those copy operations???
Second question: For what exactly is the pluginPath property? I read the description but i don't get it. Can i specify the location of my plugins in "plugins_test" for example with this property to get them built?
regards
Matthias
Re: Question about buildDirectory and pluginPath [message #493681 is a reply to message #493648] Tue, 27 October 2009 10:24 Go to previous messageGo to next message
pluginPath is a File.pathSeparator (';' or ':') separated list of paths.
This, together with buildDirectory forms a list of paths, where we
consider plugins found like this:
1) if <path>\plugins exists, then <path>\plugins\* are plugins
2) else if <path>\META-INF\MANIFEST.MF, or <path>\plugin.xml or
<path>\fragment.xml exit, then <path> is a plugin.
3) else if <path> is a folder, then <path>\* are plugins
4) else if <path> is a file ending in .jar, it is a plugin.
There is similar logic for features.
In your case, you want case (3), set pluginPath=plugins_test and
plugins_test/* will be found. This is comparable to setting pluginPath
to point to a workspace folder.
-Andrew
Matthias Kohles wrote:
> Hey everyone,
> "pluginPath".
> copy operations???
> regards
> Matthias
Re: Question about buildDirectory and pluginPath [message #493821 is a reply to message #493681] Wed, 28 October 2009 04:06 Go to previous messageGo to next message
Thanks for your reply Andrew,
Consider the following Directory structure:
<buildDirectory>/plugins
<buildDirectory>/features
<buildDirectory>/plugins_test
<buildDirectory>/features_test
For default, the plugins in "plugins" will be built, which is case 1 in your post. Now if i set the pluginPath property it will have no effect or will it? because if case 1 is "executed", it will never goes to case 3??? Or will it built both plugin directories???
Sorry, i don't understand it right now.
Matthias
Re: Question about buildDirectory and pluginPath [message #493875 is a reply to message #493821] Wed, 28 October 2009 06:50 Go to previous messageGo to next message
update:
i just tried it out and everything worked fine.
Thank you andrew for your help Smile
best regards
Matthias
Re: Question about buildDirectory and pluginPath [message #493975 is a reply to message #493821] Wed, 28 October 2009 11:56 Go to previous messageGo to next message
We are working on a list of directories, if you have
buildDirectory=<buildDirectory>
pluginPath=<buildDirectory>/plugins_test;<buildDirectory>/features_test
(use ':' on linux)
Then the list has 3 entries, <buildDirectory> gets the plugins &
features, and the 2 pluginPath entries get the other folders.
-Andrew
> Matthias
Re: Question about buildDirectory and pluginPath [message #501401 is a reply to message #493975] Wed, 02 December 2009 03:17 Go to previous messageGo to next message
Hey Andrew,
it came up a new question to me.
Doesn't the separated pluginPath list work on eclipse pde 3.3?
regards
Matthias
Re: Question about buildDirectory and pluginPath [message #602947 is a reply to message #493681] Wed, 28 October 2009 04:06 Go to previous messageGo to next message
Matthias
Re: Question about buildDirectory and pluginPath [message #602968 is a reply to message #602947] Wed, 28 October 2009 06:50 Go to previous messageGo to next message
update:
Thank you andrew for your help :)
best regards
Matthias
Re: Question about buildDirectory and pluginPath [message #602995 is a reply to message #602947] Wed, 28 October 2009 11:56 Go to previous messageGo to next message
(use ':' on linux)
-Andrew
> Matthias
Re: Question about buildDirectory and pluginPath [message #603753 is a reply to message #493975] Wed, 02 December 2009 03:17 Go to previous message
Hey Andrew,
regards
Matthias
Previous Topic:Annoying warning in build.properties
Next Topic:PDE refactoring: plugin/bundle splitter?
Current Time: Mon Jul 21 02:36:11 EDT 2025
Powered by FUDForum. Page generated in 0.31519 seconds
