Home » Modeling » OCL » Composing instances of a used-defined type(Composing instances of a used-defined type)
Composing instances of a used-defined type [message #493701] Tue, 27 October 2009 11:39 Go to next message
Is it possible to create and fill instances of a user-defined type?
For example: The user-defined type Person is composed of the following two attributes:
- name : string
- age : integer
Further a Class is defined with two attributes:
- p : string
- a : integer
and one operation:
- ComposePerson : Person
The idea is to define an OCL body expression for the operation that returns a single instance of type Person, filled with the values of the 'p' and 'a' instance values of the class instance.
So if p = "John" and a = 15, then the result of the operation shall be: { "John", 15 } (of type Person).
With kind regards,
Bjorn
Re: Composing instances of a used-defined type [message #493766 is a reply to message #493701] Tue, 27 October 2009 17:38 Go to previous messageGo to next message
Hi Bjorn
This was raised as OMG Issue 13057, where for your example the proposed
Tuple-like constructor might be:
Person{name = "John", age = 15}
The idea seems syntactically and semantically sound but awaits
further analysis and prototyping.
Ed Willink
Bjorn wrote:
> Hello,
> two attributes:
> - name : string
> - age : integer
> - p : string
> - a : integer
> and one operation:
> With kind regards,
> Bjorn
Re: Composing instances of a used-defined type [message #493902 is a reply to message #493701] Wed, 28 October 2009 09:03 Go to previous messageGo to next message
Hello Edward,
Thank you for your quick response. The issue you mention is exact that what I need. So this means I need to be patient Wink For now I will try to work-around this issue.
Kind regards,
Bjorn
Re: Composing instances of a used-defined type [message #494046 is a reply to message #493902] Wed, 28 October 2009 17:51 Go to previous message
Hi Bjorn
I had a quick play at a modified grammar. With Issue 14583 making Tuple
partially reserved, there is no syntactic prpblem with the extension.
It's just a matter of sorting out default values, and a treatment for
uninitialised values.
We might get a prototype in for Helios.
Watch https://bugs.eclipse.org/bugs/show_bug.cgi?id=293622 to see when
something's available.
Ed Willink
Bjorn wrote:
> Hello Edward,
> what I need. So this means I need to be patient ;) For now I will try to
> Kind regards, Bjorn
Previous Topic:OCL Syntax check
Next Topic:Different Figures for one Ecore class
Current Time: Thu Jul 24 22:10:54 EDT 2025
Powered by FUDForum. Page generated in 0.12356 seconds
