Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare Example(working with same instances of Ecore models)
EMF Compare Example [message #493580] Mon, 26 October 2009 23:51 Go to next message
Hello Fellow Emf compare users,
I am very new to EMF compare and have just started with it. I have downloaded all plug-ins and started working with initial examples. which worked fine for me. But now.I am having trouble in comparing and understanding Emf merge model.
1. I am comparing two models, instances of same meta model. after executing EMF compare i get *.emfdiff file i am having same left and right elements and references to them even though i am loading both from difference directories resources (But in the same resource). same names and elements but different "hrefs" for left and right model. I am confused why is it so?
2. When i try to traverse for unmatched elements (after change by adding new elements to left model) i cannot traverse it properly? (any example available)
3. I would to solve the following scenario with emf compare
model a
model b
in the beginning both are having similar elements in them .
i am changing model "a" and than comparing it with model "b". now i want to synchronize "b" w.r.t "a" automatically. Is there anyway in EMF compare untility?
thank you very much for consideration
regards
saad
Re: EMF Compare Example [message #493608 is a reply to message #493580] Tue, 27 October 2009 04:37 Go to previous messageGo to next message
--------------070504010300050905030705
Hi saad,
comments inlined below.
Laurent
Don't really understand your question here. Different hrefs means the
two elements are not "the same". You're probably looking at a
MatchElement which "left" reference points to the left model and "right"
reference to the right model. These elements allow us to match similar
elements from both models, and looking at the MatchElement in "visual"
mode (in the sample ecore editor) will probably give two elements
looking really similar if you haven't changed the name of one of the two
in one of the two models.
> available)
Sorry, don't understand your question. What does "I cannot traverse it
properly" mean? You get an exception? How do you "traverse" your
elements : in the sample ecore editor, through code, ...? Examples of a
comparison from start to finish, merge included, can be found in the
org.eclipse.emf.compare.example.standalone example.
> model a
> model b
> compare untility?
Comparing a and b is done through
DiffService.doDiff(a, b);
MatchService.doMatch(diff);
The same kind of facility is accessible for the merge through
"MergeService.merge(differences, direction)"
> regards
> saad
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------070504010300050905030705--
Re: EMF Compare Example [message #493633 is a reply to message #493608] Tue, 27 October 2009 08:09 Go to previous messageGo to next message
Thank you very much for quick feedback Laurent,
I understood answer to my 1 question.I suppose that i couldnt make you understand what my issue is?
let me try it once again
I would like to traverse unmatched elements from match model using code, after that i am again coding to merge the changes (change names) from one left model element to right one.
i tried to used the following EMF services to compare,merge the changes (renaming an element, adding new element in a) from left model (a) to right model (b)
following steps are taken
1.// ResourceSet resourceSet_right_b= new ResourceSetImp l();
//ResourceSet resourceSet_left_a= new ResourceSetImpl();
2. // registering appropriate packages and loading
Resource resource_left =resourceSet_left.getResource(some_uri, true);
// two way match
3. MatchModel match1=MatchService.doResourceMatch(resource_left, resource_right, Collections.<String,Object> emptyMap());
4. final DiffModel diff= DiffService.doDiff(match1,false);
5.final List<DiffElement> differences=new ArrayList<DiffElement>(diff.getOwnedElements());
// merging differences
MergeService.merge(differences, true);
6. storing them in snapshot and saving them as result.emfdiff
now my question is
if the code idea is right will i be able to see changes done (name change, new element added) in left model (a) into right model (b)?
if yes i am not able to see anything changed in model b. Why so?
help will be much appriciated
regards
saad
Re: EMF Compare Example [message #493646 is a reply to message #493633] Tue, 27 October 2009 08:54 Go to previous messageGo to next message
--------------020403060801040809040009
Hi Saad,
The code itself is right, the only reason I see that you wouldn't see
changes merged would be if there is no differences between your models.
If you use XMI IDs or functional IDs, set both
MatchOption.OPTION_IGNORE_XMI_ID and MatchOption.OPTION_IGNORE_ID to
true when comparing (in the Map you pass the MatchService).
Laurent Goubet
Obeo
> right model (b)
> // two way match
> now my question is
> regards
> saad
--------------020403060801040809040009--
Re: EMF Compare Example [message #493664 is a reply to message #493646] Tue, 27 October 2009 10:11 Go to previous messageGo to next message
Hello Laurent,
thank you very much for quick reply again. You are right there are no differences shown in diff model as i am just changing the name of elements and adding new ones. well I am working with two different instances of same ecore model. both models having same URI. I am adding instances in one model and want to automatically get in the other one (for synchronization purpose).
example of scenario i am trying to solve is
abc.ecore
a.instanceofe (left)
b.instanceofe (right)
initially
a={e1 (name=test1,qualifiedname=a.e1),e2(name=test2,qualifiedname= a.e2),e3=(name=test3, qualifiedname=a.e3)}
b={e1 (name=test1,qualifiedname=a.e1),e2(name=test2,qualifiedname= a.e2),e3=(name=test3, qualifiedname=a.e3)}
where e is element with attributes like name and qualified name.
now in next step i add element in left model (a)
a={e1 (name=test1,qualifiedname=a.e1),e2(name=test2,qualifiedname= a.e2),e3=(name=test3, qualifiedname=a.e3),e4=(name=test4,qualifiedname=a.e4)}
1. i dont get any differences in diff model. will i have to? i just get unmatched element tuple in match model.
2. I want to get e4 from model a and want to transfer it to model b on the right place. do i have to manually right code for that? or can EMF merge help me in this situation?
thank you very much for your support and help
best regards
saad
Re: EMF Compare Example [message #493675 is a reply to message #493664] Tue, 27 October 2009 10:31 Go to previous messageGo to next message
--------------090703020009060405020609
Saad,
EMF Compare should be able to do what you describe here, but you need to
compare the two models (calls to MatchService and DiffService) _after_
you add e4 in a. The MatchModel (MatchService.doMatch()) should indeed
return you 3 matchElements and 1 UnmatchedElement. Your DiffModel (call
to DiffService.doDiff()) should then contain one DiffElement of type
AddModelElement.
Merging its containing DiffGroup (call to
MergeService.merge(diff.getOwnedElements())) will copy this change in
the right direction. That is : if a is your left model and b the right,
and you added e4 in a; asking EMF Compare to merge from leftToRight will
add a copy of e4 in b, while asking it to merge from rightToLeft will
remove e4 from a.
I don't know if this explanation of the process helps in any way ... but
I have trouble understanding which part of this doesn't work in your case.
Laurent Goubet
Obeo
> Hello Laurent,
> abc.ecore
> initially
> best regards
> saad
--------------090703020009060405020609--
Re: EMF Compare Example [message #493679 is a reply to message #493675] Tue, 27 October 2009 10:40 Go to previous messageGo to next message
Hello Laurent
thanks again for the reply well i am sure the problem is that i am not getting any DiffElement of type AddModelElement in result.emfdiff model.
May be its a problem with installation or something else i am trying to figure this out for atleast a day or so.
saad
Re: EMF Compare Example [message #494055 is a reply to message #493580] Wed, 28 October 2009 21:36 Go to previous messageGo to next message
Hello Laurent,
I just figure out the problem. As i was using both merging and differencing at the same time so that was the reason i wasn't able to see the changes i was making and also 3 way compare better suited to solve my problem. anyhow thanks for your quick replies.
my next question is that is it possible to save merge as new file some where else on disk or serialize that as snap shot?
I want to merge file a.xml with file b.xml and save it as file c.xml on disk
regards
saad
Re: EMF Compare Example [message #494110 is a reply to message #494055] Thu, 29 October 2009 05:11 Go to previous message
--------------060105090109060305080409
Hi saad,
Saving the merged file elsewhere is not possible in this order. What you
can do is copy a.xml to c.xml (so that "a.xml" is now a backup), compare
"c.xml" with "b.xml" (instead of comparing a.xml and b.xml) and merge
all changes to c.xml. That would do the trick for you would it not?
Laurent Goubet
Obeo
> Hello Laurent,
> disk regards
> saad
--------------060105090109060305080409--
Re: EMF Compare Example [message #621521 is a reply to message #493608] Tue, 27 October 2009 08:09 Go to previous message
// two way match
now my question is
regards
saad
Re: EMF Compare Example [message #621522 is a reply to message #621521] Tue, 27 October 2009 08:54 Go to previous message
Hi Saad,
Laurent Goubet
Obeo
> right model (b)
> // two way match
> now my question is
> regards
> saad
Re: EMF Compare Example [message #621523 is a reply to message #493646] Tue, 27 October 2009 10:11 Go to previous message
Hello Laurent,
abc.ecore
initially
best regards
saad
Re: EMF Compare Example [message #621524 is a reply to message #493664] Tue, 27 October 2009 10:31 Go to previous message
Saad,
AddModelElement.
remove e4 from a.
Laurent Goubet
Obeo
> Hello Laurent,
> abc.ecore
> initially
> best regards
> saad
Re: EMF Compare Example [message #621525 is a reply to message #493675] Tue, 27 October 2009 10:40 Go to previous message
Hello Laurent
saad
Previous Topic:ecorediag missing classes in packages
Next Topic:EMF Compare Example
Current Time: Wed Jul 30 09:31:07 EDT 2025
Powered by FUDForum. Page generated in 0.10343 seconds
