Home » Eclipse Projects » Eclipse Platform » How to disable Project->Build menu item in eclipse(Disable and enable build and clean menu items in eclipse programmatically)
icon3.gif  How to disable Project->Build menu item in eclipse [message #492859] Thu, 22 October 2009 02:56 Go to next message
Does eclipse plug-in architecture provide the functionality to enable and disable the standard menu buttons of eclipse. There is a requirement in my application to disable build sub menu under project menu, using a parameter's value.
Please provide some pointers to the solution. I am able to add my own menu items but could not find a way to edit standard eclipse menu items.
Thanks in advance.
Vishal Rastogi
[Updated on: Mon, 26 October 2009 06:31] by Moderator
Re: How to disable Project->Build menu item in eclipse [message #493638 is a reply to message #492859] Tue, 27 October 2009 08:45 Go to previous message
In an RCP app you create things like the build menu in your ActionBarAdvisor, usually using org.eclipse.ui.actions.ActionFactory for common actions.
If you are simply a plugin in the eclipse workbench, you do not have access to those action/menu items.
PW
Previous Topic:Contributing a menu item to a sub-menu defined by an action provider
Next Topic:Editor toolbar action visibility
Current Time: Fri Jul 25 02:03:26 EDT 2025
Powered by FUDForum. Page generated in 0.05132 seconds
