Home » Eclipse Projects » Remote Application Platform (RAP) » setting default value in Combo doesn't trigger an event
setting default value in Combo doesn't trigger an event [message #493175] |
Fri, 23 October 2009 09:21  |
Hi all,
I've created two Combos. If I change the selection in Combo1, the value
of Combo2 should reset to default value. I got this as follows:
myCombo1.addPostSelectionChangedListener(new ISelectionChangedListener() {
public void selectionChanged(SelectionChangedEvent arg0) {
myCombo2.refresh(false);
myCombo2.getCombo().select(0);
The value is set correctly to the first in the list, but the model
behind the combo2 doesn't recognize this change. How can I achieve that
the model is updated, too?
Thanks in advance,
Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493426 is a reply to message #493203] |
Mon, 26 October 2009 04:31   |
Rüdiger Herrmann schrieb:
> did you try
> myCombo2.setSelection( StructuredSelection.EMPTY );
> in the selectionChanged method?
> HTH
> Rüdiger
Hi Rüdiger,
this doesn't set the value, too. If I select any value in combo2 and
after this select a value in combo1, the combo2 doesn't refresh its
(displayed resp. selected) value. The values inside combo2 are
refreshed. Any further hints are welcome.
Ralf.
> R. Heydenreich wrote:
>> Hi all,
>> Thanks in advance,
>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493462 is a reply to message #493426] |
Mon, 26 October 2009 08:19   |
Ralf,
I understood that you wanted to reset the selection of combo 2. This
is what "setSelection( StructuredSelection.EMPTY )" does.
If that's not what you wanted to do, then please clarify what you
actually want to achieve.
Rüdiger
>> did you try
>> HTH
>> Rüdiger
> Hi Rüdiger,
> Regards,
> Ralf.
>>> Hi all,
>>> Thanks in advance,
>>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493474 is a reply to message #493462] |
Mon, 26 October 2009 08:54   |
> Ralf,
> I understood that you wanted to reset the selection of combo 2. This is
> Regards,
> Rüdiger
Hi Rüdiger,
what I want to get is the following scenario:
1. (initial) both combos are filled with some values, and on both combos
the first value is highlighted (here marked with an asterisk):
combo1 (c1) combo2 (c2)
|*default_combo1 | |*default_a_combo2|
|c1_val_1 | |c2_val_a1 |
|c1_val_2 | |c2_val_a2 |
|c1_val_3 | |c2_val_a3 |
2. next, I select a value in combo2:
combo1 combo2
|*default_combo1 | |*c2_val_a2 |
|c1_val_2 | |default_a_co|
Nothing else happens, and this is ok.
3. Now I select another value in combo1. At this point the content of
combo2 is completely replaced by other values. And I recognize that the
new default value is displayed. But the situation is as follows:
=> WRONG
combo1 combo2
|*c1_val_2 | |*default_a_combo2|
|c1_val_1 | |default_b_co|
|default_com| |c2_val_b2 |
|c1_val_3 | |c2_val_b3 |
+-----------+ |c2_val_b3 |
The value default_a_combo2 is displayed, but it is not an element of the
content of combo2. The question is, how can I get the combo2 so that it
displays after a change in combo1 the default value default_b_combo2 and
not the previously selected value?
=> INTENDED BEHAVIOUR:
combo1 combo2
|*c1_val_2 | |*default_b_combo2|
|c1_val_1 | |c2_val_b2 |
|default_com| |c2_val_b3 |
Does this clarify my intention?
Ralf.
>>> did you try
>>> HTH
>>> Rüdiger
>> Hi Rüdiger,
>> Regards,
>> Ralf.
>>>> Hi all,
>>>> Thanks in advance,
>>>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493620 is a reply to message #493474] |
Tue, 27 October 2009 05:27   |
do you want to select an element in a combo viewer that is not part
of its content (i.e. is not returned by
IStructuredContentProvider#getElements)?
Is that what you want to achieve?
>> Ralf,
>> Regards,
>> Rüdiger
> Hi Rüdiger,
> combo1 combo2
> => WRONG
> combo1 combo2
> combo1 combo2
> Regards,
> Ralf.
>>>> did you try
>>>> HTH
>>>> Rüdiger
>>> Hi Rüdiger,
>>> Regards,
>>> Ralf.
>>>>> Hi all,
>>>>> Thanks in advance,
>>>>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493658 is a reply to message #493620] |
Tue, 27 October 2009 09:45   |
> do you want to select an element in a combo viewer that is not part of
No, I want only select the elements which are part of the list.
>>> Ralf,
>>> Regards,
>>> Rüdiger
>> Hi Rüdiger,
>> combo1 combo2
>> => WRONG
>> combo1 combo2
>> combo1 combo2
>> Regards,
>> Ralf.
>>>>> did you try
>>>>> HTH
>>>>> Rüdiger
>>>> Hi Rüdiger,
>>>> Regards,
>>>> Ralf.
>>>>>> Hi all,
>>>>>> value
>>>>>> that
>>>>>> Thanks in advance,
>>>>>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #493987 is a reply to message #493658] |
Wed, 28 October 2009 12:26   |
setSelection( new StructuredSelection( *default_b_combo2 ) );
HTH
Rüdiger
>>>> Ralf,
>>>> Regards,
>>>> Rüdiger
>>> Hi Rüdiger,
>>> combo1 combo2
>>> => WRONG
>>> combo1 combo2
>>> combo1 combo2
>>> Regards,
>>> Ralf.
>>>>>> did you try
>>>>>> HTH
>>>>>> Rüdiger
>>>>> Hi Rüdiger,
>>>>> Regards,
>>>>> Ralf.
>>>>>>> Hi all,
>>>>>>> value
>>>>>>> that
>>>>>>> Thanks in advance,
>>>>>>> Ralf.
Re: setting default value in Combo doesn't trigger an event [message #494310 is a reply to message #493987] |
Fri, 30 October 2009 04:26  |
Ah, many thanks. This was the missing line!
Greetings,
Ralf.
> HTH
> Rüdiger
>>>>> Ralf,
>>>>> This is
>>>>> Regards,
>>>>> Rüdiger
>>>> Hi Rüdiger,
>>>> combos
>>>> combo1 combo2
>>>> => WRONG
>>>> combo1 combo2
>>>> the
>>>> and
>>>> combo1 combo2
>>>> Regards,
>>>> Ralf.
>>>>>>> did you try
>>>>>>> HTH
>>>>>>> Rüdiger
>>>>>> Hi Rüdiger,
>>>>>> Regards,
>>>>>> Ralf.
>>>>>>>> Hi all,
>>>>>>>> value
>>>>>>>> that
>>>>>>>> Thanks in advance,
>>>>>>>> Ralf.
Current Time: Mon Jul 21 01:20:33 EDT 2025
Powered by FUDForum. Page generated in 0.05880 seconds
