How do you turn off the popups in the XSLT editor? [message #493079] |
Thu, 22 October 2009 21:52  |
Hi all,
Not sure if this is the right place to ask, but I'm using the XSLT editor
provided by the Eclipse Web Tools Platform (org.eclipse.wst.xsl.feature)
Unfortunately I'm having lots of problems fighting with the popup suggestion
box - it seems that almost every keypress I type results in an instant popup
window suggesting XSLT tags I can insert, even when I'm in the middle of
typing normal text. It's infuriating because when the box is on the screen I
can't use the arrow keys properly because they scroll through the choices in
the box instead of moving around between lines of code.
I've been all through the options many times but I can't find where you
disable this popup feature!
Can someone please let me know how to stop these annoying popups from getting
in my way? Or is there some other Eclipse plugin that just provides XML
syntax highlighting then gets out of my way? (I'd miss the validation but I'd
save so much time by not getting random tags inserted in my code thanks to the
popup deciding to appear just before I press Enter...)
Many thanks,
Adam.
FUDForum. Page generated in 0.57167 seconds
