Eclipse hangs when I'm running a script [message #493395] |
Sun, 25 October 2009 15:17  |
Hi!
I'm running ruby scripts through "External tools" in Eclipse. I have a prepare-script (X) that triggers a Eclipse listener (plugin) that runs another script (Y). In other words:
X - plugin - Y
The problem is that when Y produces more than 500 characters of output, Eclipse hangs. I've replaced Y with a dummy script that just do printf's, to make sure it's not a script issue. And indeed, it seems that the length of the console output (the number of characters) is the key.
When I run Y standalone or in Eclipse without the plugin, it works perfectly even with very large outputs. So I believe I'm missing something with the plugin here. Can anyone shine some light on this please?
(I'm on WinXP SP3, Eclipse 3.4.1)
/Henrik
Re: Eclipse hangs when I'm running a script [message #879592 is a reply to message #493518] |
Thu, 31 May 2012 09:41  |
Hi!
I'm sorry, I forgot to reply on this subject. Your advice was very useful and it helped me fix the code. Thank you!
Below is an overview of how I change the code. I didn't fix anything about threads, just the handling of how the plugin reads from the script. I'm just supplying the code here so that anyone else that find this thread maybe can get some help.
public class scriptListener implements IPatternMatchListenerDelegate {
public void matchFound(PatternMatchEvent event) {
PlatformUI.getWorkbench().getDisplay().syncExec(new Runnable() {
public void run() {
// This closes all old consoles.
ConsolePlugin.getDefault().getConsoleManager().removeConsoles(
ConsolePlugin.getDefault().getConsoleManager().getConsoles()
// Create a new console for the script result.
outConsole = new MessageConsole("myscript results", null);
ConsolePlugin.getDefault().getConsoleManager().addConsoles(new IConsole[] { outConsole } );
// Create a stream to the console and print the scripts output there.
MessageConsoleStream consoleStream = outConsole.newMessageStream();
// Start the external script and set up streams to read its output.
process = Runtime.getRuntime().exec("myscript "+arguments);
BufferedReader in = new BufferedReader(new InputStreamReader(process.getInputStream()));
BufferedReader err = new BufferedReader(new InputStreamReader(process.getErrorStream()));
boolean break_on_next = false;
boolean ready = false;
for (waitIndex = 0; waitIndex < (pluginMaxWaitTimeInSeconds*10); waitIndex++) {
// Read the input stream, i.e. ordinary output from the script.
ready = in.ready(); // Check if the next read operation
// is guaranteed not to block for input.
while (ready == true) { // Keep reading as long as the stream
// is ready for a new read.
line = in.readLine(); // Read one line of output.
if (line != null) {
consoleStream.println(line);
consoleStream.flush();
ready = in.ready(); // Check if the stream is
// ready for a new read.
else
ready = false;
// Read the error stream, i.e. error messages from the script.
ready = err.ready();
while (ready == true) { // For comments about this code,
// see similar code above.
line = err.readLine();
if (line != null) {
else
ready = false;
try {
// This code is a bit special since we want to do
// the last read from the scripts streams
// _after_ the script for sure has finished.
// If the script has ended, then the for-loop
// above should end on the next loop.
if (break_on_next == true)
break;
process.exitValue(); // The return value is ignored.
break_on_next = true; // When this line is reached there was
// no exception from exitValue(), i.e.
// the process is finished. Break the for-loop
// after next readLine.
} catch (IllegalThreadStateException e) {
// This exception means that the subprocess represented by this Process object
// has not yet terminated. So the for-loop above should run again.
try {
Thread.sleep(100); // Wait a while for the script to execute (milliseconds).
} catch (InterruptedException ie) {
} // End of for-loop
} catch (IOException e1) {
consoleStream.print( "Plugin error!" );
FUDForum. Page generated in 0.21708 seconds
