Home » Eclipse Projects » EclipseLink » Mapping of Collection of Base class objects
Mapping of Collection of Base class objects [message #493393] Sun, 25 October 2009 14:21 Go to next message
I have say following class structure
Class B1 and B2 inherit from Class B
And Class A has a one-to-many collection of Class B objects which could be of type B1 or B2.
I am not able to figure out how I would map these. I would like to have table-per-class inheritance strategy for Class B hierarchy if that matters.
I appreciate any help on the subject.
gopal
Re: Mapping of Collection of Base class objects [message #493487 is a reply to message #493393] Mon, 26 October 2009 10:00 Go to previous messageGo to next message
Have you tried just mapping the OneToMany in A to B? What error are you getting?
You may be better off using single_table or joined inheritance.
Re: Mapping of Collection of Base class objects [message #493565 is a reply to message #493487] Mon, 26 October 2009 18:57 Go to previous messageGo to next message
Thanks James for the reply and Sorry, it took a while for me to configure and test this scenario.
I am getting foreign key violation exception.
It created following schema
TableA(id, ...)
TableB(id,...)
TableB1(id,...)
TableB2(id,...)
TableAB(A_id, attr_id)
Constraint1) A_id Foreign Key to id in TableA
Constraint2) attr_id is foreign key to id in TableB
When I insert an item in B1 or B2, it violates constraint2 as there is no entry in table B with that id.
Based on the problem it may work if I use JOIN table or SINGLE_TABLE inheritance strategy as you suggested, but I have requirement to use TABLE_PER_CLASS.
Any other ideas?
Re: Mapping of Collection of Base class objects [message #494173 is a reply to message #493393] Thu, 29 October 2009 09:18 Go to previous message
You cannot define foreign key constraints with TABLE_PER_CLASS relationships, as there is no common table to define the constraint to. That is one of the reasons why SINGLE_TABLE or JOINED is normally recommended.
Previous Topic:provide mappings that are not on the classpath
Next Topic:JAPA search query on DB
Current Time: Mon Jul 21 11:33:28 EDT 2025
Powered by FUDForum. Page generated in 0.41291 seconds
